Dimensions of drawing view selection
raymaster
raymaster
Hello All
I need two main separate things:
1. a code that can select specific dimensions of a pre-named drawing view
2. a code that can add named annotations from assembly file to a specific pre-named view in a drawing document.
I tried to do it this way, but it selects all the dimensions:
Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    Dim oViewName As String
    oViewName = "Master_SB"
    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
    ' Get the dimensions collection for the specific view
    Dim oDimensions As DrawingDimensions
    oDimensions = oSheet.DrawingDimensions
    ' Process the dimensions (select only those in the "Master_SB" view)
    Dim oDrawDim As DrawingDimension
    For Each oDrawDim In oDimensions
        If oDrawDim.Parent.Name = oViewName Then
            oDrawDoc.SelectSet.Select(oDrawDim)
    Next
Best
A.Acheson
Hi @raymaster
If you look at the parent of drawing dimesion it is a sheet object and not view name.
Syntax
DrawingDimension.Parent() As Sheet
See this post which explains other solved methods to identify relationships.
Regards
Alan
