dimension visibility by layer control when component is active in assembly
khadeerkruthi
Message 1 of 1
khadeerkruthi
i have assembly in which it content component motor and motor with gearbox
in drawing when the assembly contains motor then layer M1 should be visible and other should be invisible,
when the assembly contains motor with gearbox then layer M2 should be visible and other should be invisible.
note layer is assigned to dimension.
Replies (0)
