Dimension style for 2 decimal place precision?
jake_egley
jake_egley
I'm using @JelteDeJong's rule to place the overall dimensions on a drawing view linked here. I want to modify the following line to add a dimension style so that the dimensions created have a two place precision (x.xx). Does anyone know the dimension style? Thanks
Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
        _sheet.DrawingDimensions.GeneralDimensions.AddLinear(
            pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
Jake Egley
Inventor 2022
J-Camper
You can capture the LinearGeneralDimension created and then set the style:
Dim lgd As LinearGeneralDimension= _sheet.DrawingDimensions.GeneralDimensions.AddLinear(
lgd.Style = 'Your DimensionsStyle Object
There is an example in the help that goes over a creating the DimensionStyle.  It's in VBA, but just remove the "Set" part of lines where they exist and it will work in iLogic: https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=DrawingDimension_Sample
Editing the style will affect all dimensions that use the style, so if you only want to change those dimensions you are creating, then you can adjust the LinearGeneralDimension.Precision property for each dimension.
cidhelp
you can also set the precision directly to the dimension object:
lgd.Precision = 0
jake_egley
Final Code to make it two decimal places is here:
        Dim lgd As LinearGeneralDimension = _sheet.DrawingDimensions.GeneralDimensions.AddLinear(
            pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType, True, oDimStyle)
		lgd.Style.LinearPrecision = kTwoDecimalPlacesLinearPrecision
Jake Egley
Inventor 2022
