Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Dimension centering, Arrows Inside, Skip small dimension
Message 1 of 15
When I use the Center Dimension Text API Sample (from Inventor help), all linear dimensions are centered.
I would like to skip all dimensions that are too small and have their arrowheads outside.
Unfortunately - although I can see the arrowheads outside in my drawing, the DrawingDimension.ArrowheadsInside property is true - so I cannot distinguish between dimensions using this property.
Other method that I tried is to check the minimal dimension value that makes the arrowheads inside. It's 6mm (don't ake me why) but only for scale 1:1 and will change according to scale of a view.
Unfortunately - I can get the value of dimension and I can get the scale of a view, but I don't see how to connect them. It seems that both dimensions and views are parts of sheet, but I cannot see how to check, on which view is specific dimension.
Changing dimension style in not an option.
Maybe You have an another solution?
Replies (14)
Message 2 of 15
JhoelForshav
Hi @Anonymous
If you measure the dimensionline it'll always be in cm units on the drawing sheet. So the scale doesn't matter in that case.
Try this and see if it works for you 🙂
Public Sub CenterAllDimensions()
    ' Set a reference to the active drawing document
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oDrawingDim As DrawingDimension
    ' Iterate over all dimensions in the drawing and
    ' center them if they are linear or angular.
    For Each oDrawingDim In oSheet.DrawingDimensions
        If TypeOf oDrawingDim Is LinearGeneralDimension Or _
           TypeOf oDrawingDim Is AngularGeneralDimension Then
           Dim oLength As Double
            Call oDrawingDim.DimensionLine.Evaluator.GetLengthAtParam(0, 1, oLength)
            If oLength > 0.6 Then Call oDrawingDim.CenterText
        End If
    Next
End Sub
Message 3 of 15
As You can see scale of a view matters.
Your solution would work only if multiplied by scale of a view
Message 4 of 15
JhoelForshav
@tomasz.dabrowskiUGC2B
The dimensionline is not part of the drawing view so it's not affected by the drawing view scale. Its dimension is the length of it on the drawing sheet.
Message 5 of 15
It's strange, but on my computer it doesn't work.
I put screens before and after running macro
Message 6 of 15
robertast
Surprisingly, for me, this rule works both as a macro and as an iLogic. And works great. Thanks @JhoelForshav
Message 7 of 15
robertast
Here's a video of how it works for me
Message 8 of 15
JhoelForshav
@Anonymous
It's very strange... See if it works better to get the paramextents first and not just use 0 & 1. I doubt it'll make a difference but still.
    Dim oSheet As Sheet
           Dim minParam As Double
           Dim maxParam As Double
           Call oDrawingDim.DimensionLine.Evaluator.GetParamExtents(minParam, maxParam)
            Call oDrawingDim.DimensionLine.Evaluator.GetLengthAtParam(minParam, maxParam, oLength)
            End If
        End If
    Next
End Sub
 Also, try running this iLogic rule and pick the dimension that shouldn't be updated to see what length value it will return:
Dim oDim As LinearGeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Pick the dimension")
Dim minParam, maxParam As Double
oDim.DimensionLine.Evaluator.GetParamExtents(minParam, maxParam)
oDim.DimensionLine.Evaluator.GetLengthAtParam(minParam, maxParam, oLength)
MsgBox(oLength)
Message 9 of 15
I'll try Your advices later, but for now I added one line of code, which will show length of every dimension line.
I put it right before cenetring command:
MsgBox ("Dimension " & oDrawingDim.Text.Text & " has Dimension Line " & oLength)
Result is in the attachment
You can see that with different scales, length of dimension line is the same
Message 10 of 15
JhoelForshav
This is really interesting... Could you attach the ipt and dwg so I can investigate? 🙂
Message 11 of 15
Geting the paramextents didn't help - the same resut.
Picking method doesn't work on my computer - rule works, but I'am unable to click on dimension.
But I can get the dimesionline length manualy.
On my drawing now I have only 2 dimensions - both show 3(mm) but are on different scales.
Here is what I see in locals window:
Now I can calculate the difference between X, Y and Z for MinPoint and MaxPoint.
For X is 0, for Z is almost 0 (should be 0 but doesn't matter) and for Y in both cases is 0,3
I attach both ipt and dwg files as requested
Message 12 of 15
robertast
You have something wrong with the details. I refined your details in the drawing, added new ones and added dimensions. Everything seems to work ...
Only with me version 2021
Message 13 of 15
JhoelForshav
Hi @Anonymous
I see what it is now... You have set your general dimension type of the drawing views to true. This means the dimension is actually based on the 3D-model geometry and not the lines on the drawing. So the dimensionline is not a LineSegment2d but a LineSegment (3d) and it comes from the model itself...
This setting is for isometric views so you can set a dimension that represents the actual length in the model rather lengths based on the drawing curves... When placing a non-isometric view this setting should be false per default. Have you overridden it?
Try this:
1. Delete the dimensions
2. Right click the view > General Dimension Type > Projected
3. Place the dimensions again
4. Run the script.
That should do it 🙂
Message 14 of 15
Bingo.
Changing General Dimension Type from True to Projected solves my problem.
I also had to change the value >0.6 to >=0.48 (I found this value experimentally), but don't really know why.
I just wonder why I had this "true" dimension type. In other drawings I have this set to "projected".
Case solved - Thank You very much
Message 15 of 15
robertast
For dimensions to behave correctly in drawings, please vote in the topic
https://forums.autodesk.com/t5/inventor-ideas/arrange-dimension/idi-p/10776235
