Dimension between two points
Damian_Apex
Damian_Apex
I would like to create dimension between two points, but I get an error that I can't fix.
This is a snippet of larger code, hopefully it is readable
Public Sub PlaceDimension(oDoc As Document, oSheet As Sheet, oAssem As AssemblyDocument,
ViewName As DrawingView, PositionX As Double, PositionY As Double,
AttrSetName1 As String, AttrName1 As String, AttrValue1 As String,
AttrSetName2 As String, AttrName2 As String, AttrValue2 As String) 'RULE TO ADD ONE DIMENSION
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oGeneralDims As GeneralDimensions
oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions
Dim aoEdge4 As Edge
Dim aoEdge3 As Edge
oObjs1 = oAssem.AttributeManager.FindObjects(AttrSetName1, AttrName1, AttrValue1)
oObjs2 = oAssem.AttributeManager.FindObjects(AttrSetName2, AttrName2, AttrValue2)
aoEdge4 = oObjs1.Item(1)
aoEdge3 = oObjs2.Item(1)
oDrawingViewCurves1 = ViewName.DrawingCurves(aoEdge4)
oDrawingViewCurves2 = ViewName.DrawingCurves(aoEdge3)
Dim aoDrawingCurve4 As DrawingCurve
Dim aoDrawingCurve3 As DrawingCurve
aoDrawingCurve4 = oDrawingViewCurves1.Item(1)
aoDrawingCurve3 = oDrawingViewCurves2.Item(1)
Dim oPt2 As Point2d
oPt2 = oTG.CreatePoint2d(PositionX, PositionY)
Dim GeoIntent1 As GeometryIntent
Dim GeoIntent2 As GeometryIntent
GeoIntent1 = oSheet.CreateGeometryIntent(aoDrawingCurve3.MidPoint)
GeoIntent2 = oSheet.CreateGeometryIntent(aoDrawingCurve4.MidPoint)
oDim2 = oGeneralDims.AddLinear(oPt2, GeoIntent1, GeoIntent2)
oDim2.CenterText
End Sub
WCrihfield
Hi @Damian_Apex.  Can you post the screen captured images of the information shown on both tabs of the error dialog when it pop's up, that way we might get a better idea about what is going wrong.  One thought I had about this code though is that it seems to me like you might be trying to identify and find 'named geometry' from the assembly.  If so, this may not work, because the normal 'named geometry' system only works with Part documents, not assembly documents.  Also in an assembly, any Edge type objects you might retrieve will be EdgeProxy objects, which represent a component's Edge within the assembly space, so the object variables would already be the wrong Type.  This type of situation can be pretty tricky to automate by code, due to the whole proxy objects issue, and lack of support for named entities support in assemblies directly.
Wesley Crihfield
(Not an Autodesk Employee)
Damian_Apex
@WCrihfield I am using similar code to retrieve two faces from assembly and it's working.
When it comes to edges I get them correctly and their mid points but when I am trying to use them to create dimension I get error.
This is my code for adding dimensions between two faces and it's working fine.
	Dim aoFace4 As Face
	Dim aoFace3 As Face
	aoFace4 = oObjs1.Item(1)
	aoFace3 = oObjs2.Item(1)
	oDrawingViewCurves1 = ViewName.DrawingCurves(aoFace4)
	oDrawingViewCurves2 = ViewName.DrawingCurves(aoFace3)
	Dim oPt2 As Point2d
	Dim oDim2 As GeneralDimension
	oDim2 = oGeneralDims.AddLinear(oPt2, oSheet.CreateGeometryIntent(aoDrawingCurve3), oSheet.CreateGeometryIntent(aoDrawingCurve4))
	oDim2.CenterText
End Sub
In attachment screens of error.
JhoelForshav
Hi @Damian_Apex
To add a dimension between the midpoints of two drawingcurves, use the drawingcurve as the first argument and PointIntentEnum.kMidPointIntent as the second argument in the CreateGeometryIntent method.
I've attached a simple example that lets you pick two curves in a drawingview. The code will then add a lineardimension between them. I hope this helps 🙂
Dim oCurveSeg1 As DrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick first curve")
Dim oCurveSeg2 As DrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick second curve")
Dim oCurve1 As DrawingCurve = oCurveSeg1.Parent
Dim oCurve2 As DrawingCurve = oCurveSeg2.Parent
Dim oSheet As Sheet = ActiveSheet.Sheet
'Use kMidPointIntent
Dim oIntent1 As GeometryIntent = oSheet.CreateGeometryIntent(oCurve1, PointIntentEnum.kMidPointIntent)
Dim oIntent2 As GeometryIntent = oSheet.CreateGeometryIntent(oCurve2, PointIntentEnum.kMidPointIntent)
Dim oVector As Vector2d = oCurve1.MidPoint.VectorTo(oCurve2.MidPoint)
oVector.ScaleBy(0.5)
Dim oTextPoint As Point2d = oCurve1.MidPoint
oTextPoint.TranslateBy(oVector)
oSheet.DrawingDimensions.GeneralDimensions.AddLinear(oTextPoint, oIntent1, oIntent2)
Damian_Apex
@JhoelForshav thank you for help
I just need to modified this line in my code and it works as I wanted.
oSheet.CreateGeometryIntent(aoDrawingCurve3, PointIntentEnum.kMidPointIntent)
