Detrmining SketchLine Type from API
As you can (hopefully) see in the screenshot below, highlighting the a sketch from the browser, two distinct types of sketch lines are highlighted -- the actual profile lines in green/yellow, and the dotted lines in blue. I am trying to get the actual profile lines and filter out these dotted lines, however from the API, it seems both are label as SketchLines (I am using C#).
Does anyone know of a way to select out only the sketchlines actually used in the creation of the shape?
Philip
I believe I have found a solution.
Look for SketchEntity.Construction.
