Determine whether part file is a sketch
youann21700
youann21700
Morning,
I have a few rules that scan folders and determine part properties (generic material checker/drawing state checker).
I want these rules to skip certain types of parts, i.e. Sketch parts. Files used in pipe runs (XXXX.Route.01.ipt files)/frame generator skeletons. If there an easy way to differentiate these .ipt files from "regular" .ipt files.
WCrihfield
Hi @youann21700.  If there was always something unique about their file names, such as the "Route" term in your example, then you could likely check for that term in their file names.  But other than that, I don't think there is anything at the 'file' level that can be checked to determine that specific difference.  At the purely iProperty level, a model file that only contained sketches, and no features, would not have any 'Mass', and may not have any 'Volume' either, which could be checked for.  But the next step would likely be checking something like:
If oDoc.ComponentDefinition.Features.Count = 0 Then
and
If oDoc.ComponentDefinition.Sketches.Count > 0 Then
...but only after you have determined that it is a model file (.ipt or .iam), instead of a drawing (.idw or .dwg), because drawings don't have a ComponentDefinition.  Just some initial thoughts.
Wesley Crihfield
(Not an Autodesk Employee)
cidhelp
Hi @youann21700,
for frames / tube&pipes you can use the Document.DocumentInterests collection.
In Frames there are DocumentInterests with Names like:
FrameDoc
FrameMemberDoc
SkeletonDoc
EndPlate
Tube&Pipes have these DocumentInterests:
Piping Runs Environment
Piping Run Environment
Piping Hose Environment
Piping Segment
Piping Route Environment
Perhaps there are some more of such DocumentInterest's.
