Add a new column to ipart table with an iLogic rule
aalihaidar_1995
Message 1 of 1
aalihaidar_1995
I wrote an iLogic rule to create new parameter "MetalMass" in ipart and I want to update the rule to add this parameter "MetalMass" in the ipart table.
Sub Main()
    ' Ensure the document is an active part document
    Dim oPartDoc As PartDocument
    Try
        oPartDoc = ThisApplication.ActiveDocument
    Catch
        MessageBox.Show("No active part found.", "Error")
        Exit Sub
    End Try
    If oPartDoc.DocumentType <> kPartDocumentObject Then
        MessageBox.Show("This rule must be run in a part document.", "Error")
        Exit Sub
	' Check if the part is a sheet metal part; if not, exit with a message
    If ThisApplication.ActiveDocument.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		MessageBox.Show("This rule requires a sheet metal part. The active document is not a sheet metal part.", "Error")
        Exit Sub
    ' Access the iPart table (Factory)
    Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
    Dim oTable As iPartFactory = oPartCompDef.iPartFactory
    ' Check if iPart table exists
    If oTable Is Nothing Then
        MessageBox.Show("This part does not have an iPart table.", "Error")
        Exit Sub
    ' Access the model parameters
    Dim oParams As Parameters = oPartCompDef.Parameters
	iProperties.Value("Custom", "MetalMass") = 0
	Dim oRow As iPartTableRow
    For Each oRow In oTable.TableRows
        ' Make this the active row so the model will recompute
        oTable.DefaultRow = oRow
        ' Update the document to ensure parameter values reflect the active row
        oPartDoc.Update()
		Thickness = oParams.Item("Thickness").Value
		Dim extents_area As Double = SheetMetal.FlatExtentsArea
		Dim MetalVolume As Double = (extents_area * Thickness) / 1000000000
		Dim MetalDensity As Double = iProperties.Mass / (iProperties.Volume / 1000000000)
		Dim MetalMass As Double = Round(MetalVolume * MetalDensity, 2)
		iProperties.Value("Custom", "MetalMass") = MetalMass
    Next
	' Activate the first row
	oTable.DefaultRow = oTable.TableRows.Item(1)
    ' Update document to reflect changes
    oPartDoc.Update()
	InventorVb.DocumentUpdate()
	ThisApplication.ActiveDocument.Update()
    MessageBox.Show("All parameters updated for all iPart rows!", "Success")
End Sub
Replies (0)
