Determine Largest and second largest Parameter Values
I am trying to determine the 1st and 2nd largest values out of 3 parameters.  I am trying to use a nested if function to determine this, then write the values of the parameters to iProperties.
This is what I have so far.
If (ZDIM > XDIM) AndAlso (ZDIM > YDIM) Then
		iProperties.Value("Custom", "LENGTH")= Ceil(Parameter("ZDIM"))
		If YDIM>XDIM Then
				iProperties.Value("Custom", "WIDTH") = Ceil(Parameter("YDIM"))
			Else
				iProperties.Value("Custom", "WIDTH") = Ceil(Parameter("XDIM"))
		End If
	ElseIf (YDIM > XDIM) AndAlso (YDIM > ZDIM) Then
		iProperties.Value("Custom", "LENGTH")= Ceil(Parameter("YDIM"))
		If XDIM>ZDIM Then
			Else
				iProperties.Value("Custom", "WIDTH") = Ceil(Parameter("ZDIM"))
		End If
	ElseIf (XDIM > YDIM) AndAlso (XDIM > ZDIM) Then
		iProperties.Value("Custom", "LENGTH")= Ceil(Parameter("XDIM"))
		If YDIM>ZDIM Then
			Else
		End If
End If
I don't get any errors, and no values are written to iProperties.
HermJan.Otterman
you code works.
I tested it in Inventor 2017
At first I thought that it might not work, bacause of the "Ceil", to round parameters. They have to be unitless, but even with Units it worked.
my screencast : http://autode.sk/2n0ArSI
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
rhasell
Hi
Try this.
Here is a bit of code I wrote for you. You can modify it as you wish.
Change the order to suit (0,1,2)
	Dim sizes As New List(Of Double)
			sizes.Add(Parameter("ZDIM"))
			sizes.Add(Parameter("XDIM"))
			sizes.Add(Parameter("YDIM"))
			sizes.Sort()
			Parameter("HEIGHT") = sizes(2)
			Parameter("WIDTH") = sizes(1)
			Parameter("LENGTH") = sizes(0)
Reg
2026.1
That's very strange.   Nothing I do gets it to work.  The lines that write to iProperties work fine on their own, but once I add the if statements, nothing.
Beautiful.  I was trying to get to something like this, but dont have enough VBA experience to write it off-hand.
I modified it slightly to write to iProperties instead of parameters.
			sizes.Add(Ceil(Parameter("ZDIM")))
			sizes.Add(Ceil(Parameter("XDIM")))
			sizes.Add(Ceil(Parameter("YDIM")))
			sizes.Sort()
			iProperties.Value("Custom", "THICKNESS") = sizes(0)
			iProperties.Value("Custom", "WIDTH") = sizes(1)
			iProperties.Value("Custom", "LENGTH") = sizes(2)
rhasell
Hi
My VBA skills are pretty poor as well.
The Help file has a lot of info and code snippets. Most of my code started out as cut and paste, I then debug it with message boxes and small snippets, I then adjust it to suit my needs.
Always glad to help.
Reg
2026.1
