Determine if SubAssembly was created with Design Assistant
Maxim-CADman77
Advisor Advisor
Message 1 of 11
Maxim-CADman77
I wonder how can I determine if subassembly was created with Design Assistant.
AFAIK subassembly created with Cable&Harness has "HarnessAssembly" as DocumentInterest.Name
When I read this value for spring subassembly created with Design Assistant I get "ClientObjectVersion". I found no references to this value in API help ... if it what I'm looking for?
Please vote for Inventor-Idea Text Search within Option Names
Replies (10)
Message 2 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Unfortunately, Inventor API does not support for Design Assistant. Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 11
Maxim-CADman77
What "ClientObjectVersion" means (i don't see it in the API)?
Message 4 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Can you please provide reproducible steps, source code and dataset to investigate? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 11
LukeDavenport
Hi @MaximUdod
From your description it sounds as if you want to identify whether a sub assembly was created with a design accelerator (such as the spring generator in the 'Design' tab) not Design Assistant (which is a simple file management system for Inventor).
This might help Chandra to assist you,
Luke
Message 6 of 11
Maxim-CADman77
You are right - there is a mistake in the name of Inventor Component in the initial Description of the issue (and thread subject).Thank you for noting that.
Message 7 of 11
Maxim-CADman77
 Is it possible by means of Inventor API determine that SubAssembly was created with Design ACCELERATOR (not Assistant)?
Message 8 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Unfortunately, Inventor API does not support Design Accelerator. Please log this wish list at idea station using below link.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 11
LukeDavenport
It is possible.
See this Autodesk article - you need to use the 'HasInterest' method.
https://adndevblog.typepad.com/manufacturing/2012/08/identify-parts-created-by-frame-generator-with-...
Here's a more general purpose function I used a while ago. I haven't tested it recently though. Let me know if it helps.
Luke
    Function CheckDesignAccDocTypes(ByVal oDoc As Document) As Boolean
        Dim oTypeList As New List(Of String)
        oTypeList.Add("Piping Runs Environment")
        oTypeList.Add("Piping Run Environment")
        oTypeList.Add("Piping Route Environment")
        oTypeList.Add("Piping Hose Environment")
        oTypeList.Add("HarnessPart")
        oTypeList.Add("HarnessAssembly")
        oTypeList.Add("NailboardDrawing")
        oTypeList.Add("SkeletonDoc")
        TypeList.Add("FrameMemberDoc")
        oTypeList.Add("FrameDoc")
        For Each S As String In oTypeList
            If oDoc.DocumentInterests.HasInterest(S) Then
                Return True
            End If
        Next
        Return False
    End Function
Message 10 of 11
Maxim-CADman77
Thank you. Your function returned false on the sample attached.
I guess for ny needs function should be like this:
If oDoc.DocumentInterests.HasInterest("ClientObjectVersion") Then
Return True
End if
Return False
End Function
Have I understand you correctly?
PS:
Supposedly for Design Accelerator:
  DocumentInterest.Name = "ClientObjectVersion"
  Document.Interest.ClientID = "BB8FE430-83BF-418D-8DF9-9B323D3DB9B9"
PPS:
There is a thread referencing some ClientIDs strting from this message -
https://forums.autodesk.com/t5/inventor-customization/ilogic-save-assembly-copy-amp-replace-specifie...
Message 11 of 11
dba78
I think, your Code should check for the ClientId instead of the name
...HasInterest("{BB8FE430-83BF-418D-8DF9-9B323D3DB9B9}")  , which is the clientId of the Design Accelerator Addin. The Interest.Name could vary by type of the accelerator used (not tested... just an assumption)
As for finding out, which accelerator was used, there is an Attributeset "FDesign" on the ComponentOccurrence Object in the hosting assembly. This Contains an Attibute Named: "Data". This contains some XML-Fomatted Info about the creator. Not checked yet, but I guess, this info will be present for all DA-created Components. I guess the Class Names and/or clientId-s may map to the definitions in the DA-Xmls (Desing Data Directory)
HTH,
Daniel
Daniel Balogh
Application Engineer/Developer
cad-balogh.com
