detecting modelling changes
omartin
omartin
Hello, I am trying to get the updated range box of a part after it has been edified.
but my returned results are always, the dimensions before entering a sketch.
If I edit the extrusion, then the returned values update as expected
My guess is it cant capture the updated the geometry on exiting the sketch, I also tried throwing in various part.Updates before printing the value but no luck.
any suggestions would be great!
I am just working in the vba editor right now, I have just a form with the following:
In the module I have declared:
Dim WithEvents ae As ApplicationEvents
Dim WithEvents PE As PartEvents
Dim p As PartDocument
on form load I have:
Private Sub UserForm_Initialize()
Set ae = ThisApplication.ApplicationEvents
Set p = ThisApplication.activeDocument
Set PE = p.ComponentDefinition.PartEvents
End Sub
I have been messing around with these two calls, but the returned value is always an edit behind
Private Sub ae_OnNewEditObject(ByVal EditObject As Object, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
If BeforeOrAfter = kAfter Then
Debug.Print "eidt object.." & p.ComponentDefinition.RangeBox.MaxPoint.X
End If
or
Private Sub PE_OnSurfaceBodyChanged(ByVal Context As NameValueMap, ByVal BeforeOrAfter As EventTimingEnum, HandlingCode As HandlingCodeEnum)
Debug.Print "surface change.." & p.ComponentDefinition.RangeBox.MaxPoint.X
End Sub
Was my reply Helpful ? send a Kudos or accept as solution
HideoYamada
Hello omartin,
I tried OnDocumentChange event and got a change of the RangeBox value.
private void ApplicationEvents_OnDocumentChange(_Document DocumentObject, EventTimingEnum BeforeOrAfter, CommandTypesEnum ReasonsForChange, NameValueMap Context, out HandlingCodeEnum HandlingCode)
    HandlingCode = HandlingCodeEnum.kEventNotHandled;
    if (DocumentObject is PartDocument doc)
        Debug.WriteLine("OnDocumentChange : " + doc.ComponentDefinition.RangeBox.MaxPoint.X);
Result is...
OnDocumentChange : 2.95061836209214    <--- Editing the sketch started.
OnDocumentChange : 0
OnDocumentChange : 4.24891304244134 <--- Exited from the sketch.
Keep it mind...
1) HandlingCode must be set to kEventNotHandled.
2) You shoud check the value when BeforeOrAfter = kAfter and doc.ActivatedObject is Nothing.
     (If you use OnDocumentChange event)
Best Regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
omartin
Cool! I should be able to work with this.
Thanks for the info Hideo !!
HideoYamada
I'm glad if I could you help.
And I more thing...
If you want to detect the part is changed or not, you can check ModelGeometryVersion instead of RangeBox.
Best Regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
omartin
Thanks again Hideo, that is a very useful property I have never came across before, good to know!
