Detecting if a component occurrence is a virtual component
mrattray
Advisor Advisor
mrattray
I have an easy one for you guys,
I need a way to tell if a component occurence is a virtual component.
I'm using a For Each loop to cycle through all of the components in an assembly, and if the component is itself an assembly to set the LOD to "Custom". I'm using the definition document descriptor object for this. It all woks fine until the loop comes across a virtual component which doesn't have a definition document, so I need a way to check if the component is virtual and needs to be skipped.
Here's the code:
Option Explicit
Imports Inventor.LevelOfDetailEnum
Sub Main
iLogicVb.UpdateWhenDone = True
Dim doc As AssemblyDocument
Dim oLOD As LevelOfDetailRepresentation
Dim oAsmCompDef As ComponentDefinition
Dim oComp As ComponentOccurrence
Dim oComps As ComponentOccurrences
doc = ThisDoc.Document
If doc.ComponentDefinition.RepresentationsManager.ActiveLevelOfDetailRepresentation.LevelOfDetail <> kCustomLevelOfDetail Then
	oAsmCompDef = doc.ComponentDefinition
	oLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Custom")
	oLOD.Activate(True)
End If
oComps = doc.ComponentDefinition.Occurrences
On Error Goto handle
For Each oComp In oComps
	If oComp.Suppressed = False Then
		If oComp.ReferencedDocumentDescriptor.ReferencedDocumentType = kAssemblyDocumentObject Then
			If oComp.ActiveLevelOfDetailRepresentation <> "Custom" Then
				oComp.SetLevelOfDetailRepresentation("Custom", True)
			End If
			'MsgBox("Name: " & oComp.Name & "  LOD: " & oComp.ActiveLevelOfDetailRepresentation)
		'Else
			'MsgBox("doc type: " & oComp.ReferencedDocumentDescriptor.ReferencedDocumentType)
			'Exit For
		End If
	End If
Next
Exit Sub
handle:
MsgBox("LOD releated error in: " & oComp.Name, vbOKOnly, "LOD error")
End Sub
Mike (not Matt) Rattray
Curtis_Waguespack
Hi mrattray,
This is just what I had handy in my custom snippets collection.
I hope this helps.
Curtis
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components
'(in case a virtual component trips things up)
If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
'Show occurrence name In the message box body
MessageBox.Show(oOccurrence.Name, "iLogic")
Else
End If
Next
mrattray
Thanks Curtis, that was exactly what I was looking for!
For future thread searchers, here's the modified version:
 Option Explicit
Sub Main
	oLOD.Activate(True)
End If
		If Not TypeOf oComp.Definition Is VirtualComponentDefinition Then
				End If
			End If
		End If
	End If
Next
Exit Sub
handle:
End Sub
