Detect when a balloon is covering a drawing curve
MJBusseyMS
MJBusseyMS
Is there a way through the Inventor API to detect if a drawing balloon is covering up a drawing curve in a view?  Would like to know when a balloon that I place is covering up any drawing curves in a view so I can move the balloon out of the way of the curves without moving it all of the way outside of the view.
JhoelForshav
Hi @MJBusseyMS
I managed to create this iLogic rule to detect all drawingcurves that is covered by the balloon, with a lot of help from here: https://adndevblog.typepad.com/manufacturing/2016/07/get-closest-point-on-drawingcurve.html
The code lets you select a balloon and then all curves that are covered by it will turn green.
Note that the code only works if "Scale to text height" is off.
This is because i use the ballon diameter from its style.
Dim oBln As Balloon = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingBalloonFilter, "Pick balloon")
Dim oView As DrawingView = oBln.ParentView
Dim oRadius As Double = oBln.Style.BalloonDiameter * 0.5
Dim oPoint As Point2d = oBln.Position
Dim oPickPtX = oPoint.X
Dim oPickPtY = oPoint.Y
Dim oEvaluator As Curve2dEvaluator
For Each oCurve As DrawingCurve In oView.DrawingCurves
	oEvaluator = oCurve.Evaluator2D
	Dim oMinP, oMaxP
	oEvaluator.GetParamExtents(oMinP, oMaxP)
	Dim dLen As Double
	Call oEvaluator.GetLengthAtParam(oMinP, oMaxP, dLen)
	Dim dInc As Double
	dInc = dLen / 100  'consider 100 points
	Dim dLenInc As Double
	dLenInc = 0
	Dim dparams(0) As Double
	dparams(0) = oMinP
	Dim iCnt As Integer
	For iCnt = 0 To 100
		Dim dParam As Double
		Call oEvaluator.GetParamAtLength(oMinP,
		dInc * iCnt,
		dParam)
		Dim dPts(1) As Double
		dparams(0) = dParam
		Call oEvaluator.GetPointAtParam(dparams, dPts)
		Dim oEachDis = Math.Sqrt(Math.Pow((dPts(0) -oPickPtX), 2) +
		Math.Pow((dPts(1) -oPickPtY), 2))
		If (oEachDis < oRadius) Then
			oCurve.Color = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
			Exit For
	Next
Next
Hope it helps! 🙂
