Hi @MJBusseyMS
I managed to create this iLogic rule to detect all drawingcurves that is covered by the balloon, with a lot of help from here: https://adndevblog.typepad.com/manufacturing/2016/07/get-closest-point-on-drawingcurve.html
The code lets you select a balloon and then all curves that are covered by it will turn green.
Note that the code only works if "Scale to text height" is off.
This is because i use the ballon diameter from its style.
Dim oBln As Balloon = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingBalloonFilter, "Pick balloon")
Dim oView As DrawingView = oBln.ParentView
Dim oRadius As Double = oBln.Style.BalloonDiameter * 0.5
Dim oPoint As Point2d = oBln.Position
Dim oPickPtX = oPoint.X
Dim oPickPtY = oPoint.Y
Dim oEvaluator As Curve2dEvaluator
For Each oCurve As DrawingCurve In oView.DrawingCurves
oEvaluator = oCurve.Evaluator2D
Dim oMinP, oMaxP
oEvaluator.GetParamExtents(oMinP, oMaxP)
Dim dLen As Double
Call oEvaluator.GetLengthAtParam(oMinP, oMaxP, dLen)
Dim dInc As Double
dInc = dLen / 100 'consider 100 points
Dim dLenInc As Double
dLenInc = 0
Dim dparams(0) As Double
dparams(0) = oMinP
Dim iCnt As Integer
For iCnt = 0 To 100
Dim dParam As Double
Call oEvaluator.GetParamAtLength(oMinP,
dInc * iCnt,
dParam)
Dim dPts(1) As Double
dparams(0) = dParam
Call oEvaluator.GetPointAtParam(dparams, dPts)
Dim oEachDis = Math.Sqrt(Math.Pow((dPts(0) -oPickPtX), 2) +
Math.Pow((dPts(1) -oPickPtY), 2))
If (oEachDis < oRadius) Then
oCurve.Color = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
Exit For
End If
Next
Next
Hope it helps! 🙂
