Design Tracking Properties of parts through assembly using apprentice server
danijel.radenkovic
danijel.radenkovic
Hello friends,
I have another problem. I am trying to get idea how to get properties (author, revision...) of all parts from an opened assembly using apprentice server.
Any idea?
Thanks in advance
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
YuhanZhang
You can find all referenced part document in ApprenticeServerDocument.AllReferencedDocuments(check the document type) and read their properties then. Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
danijel.radenkovic
Hello yuhanzhang,
Thank you for the answer, I solved the problem few days before your reply but I forgot to share solution. Code is below and thank you very much for trying to help me.
    Dim apprentice As Inventor.ApprenticeServerComponent
    Dim partDoc As Inventor.ApprenticeServerDocument
    Dim partPropSet As Inventor.PropertySet
    Dim partProp As Inventor.Property
    Dim partPath As String
For Each occ As Inventor.ComponentOccurrence In apprenticeDoc.ComponentDefinition.Occurrences
                If occ.DefinitionDocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
                    DIM partName as String
                    partName=occ.Name
                    Dim stFilePathAndName As String
                    stFilePathAndName = openFileDialog1.FileName
                    partPath = Path.GetDirectoryName(stFilePathAndName)
                    partDoc = apprentice.Open(partPath & "\" & partName & ".ipt")
                    partPropSet = partDoc.PropertySets.Item("Design Tracking Properties")
                    partProp = partPropSet.Item("Part Number")
                    DataGridView1.Rows.Add(partName,partProp.Value)
            Next
