Design Doctor
Design Doctor
Skadborg.NTI
Design Doctor
Skadborg.NTI
Can I in any way see if the Design Doctor "is active" - i.e. detect if I have a Red Cross:
There is a sample in the help, "Using Inventor's error dialog API Sample", but I can only record errors. I am running a long configuration rule, and I want to make sure that I don't start out with "legacy" errors.
BrianEkins
There were plans at one point to expose the Design Doctor through the API but it never happened.  However, you can still get some failure or error information by interrogating the model.  The VBA macro and function below check to see if any of the features in a part have problems.  To do a full check you would also want to check the health state of sketches and work features.
Public Sub TestProblems()
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    If PartHasProblems(partDoc) Then
        MsgBox "Part has problems"
    Else
        MsgBox "Part is OK"
    End If
End Sub
Public Function PartHasProblems(partDoc As PartDocument) As Boolean
    Dim feature As PartFeature
    For Each feature In partDoc.ComponentDefinition.Features
        If feature.HealthStatus <> kUpToDateHealth And _
           feature.HealthStatus <> kBeyondStopNodeHealth And _
           feature.HealthStatus <> kSuppressedHealth Then
            PartHasProblems = True
            Exit Function
        End If
    Next
    PartHasProblems = False
End Function
Brian Ekins
Skadborg.NTI
Good idea - thank you 🙂
martinkasparides
Please, is this possible for drawing document, too? Thanks
BrianEkins
There is currently zero API capability for the drawing functionality.
Brian Ekins
steveh5
Gang...
It's Inventor 2023 now. Any update on this? Still have to use VBA?
We are now putting welds into assemblies and when they fail, it's easily over-looked. Just want a message box that pops up when the the red cross is active telling the user that something is wrong. Plan on triggering it before a save. Unsure if I want to do just welds or when anything is wrong in an assembly. Might open a can of worms, but ohh well 🙂
Best,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
g.georgiades
I am seeing success by testing the button state (assuming the design doctor button is on the drawing quick access toolbar)
Dim rb = ThisApplication.UserInterfaceManager.Ribbons.Item("Drawing").QuickAccessControls.Item("AppDesignDoctorCmd")
If rb.ControlDefinition.Enabled Then
	MsgBox("Drawing has broken elements!")
End If
