design copy with MIRROR of Assembly
cad
cad
Hello all,
It should be the simple way but I am missing something.
I made a RIGHT HAND side Main Assembly which contains sub-assemblis also a Frame Generator.
All the parameters RUN through XLS file.
Can I get a Copy of the same Assembly to get Mirror (LEFT HAND SIDE Assembly).
I tried few things.
One of them as below.
Made a New Assembly Name TMP Assembly.
Placed RIGHT HAND SIDE Main Assembly.
Mirror RHS Assembly.
Got LHS Assembly in TMP Assembly.
But LHS Assembly doesn't change properly as RHS Assembly while changing parameters in XLS.
I wanted to suppress RHS Assembly in TMP Assembly. And to use TMP Assembly as LHS Assembly.
I think, still I am going wrong way.
Looking for proper options to get it.
Thanks.
cad
Oops !!!
Sorry
I post it here by mistake.
I think this post need to be in "Inventor General Discussion".
Jef_E
Mirror the assembly? Create a derived assembly with mirror over plane XY?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
