Derived Assembly Associative option
Ktelang
Ktelang
Hello Everybody,
PLease can any one help me finding this property
I want to un check this associativity thru VBA
' Create Derived Assembly Definition for the file Filename
Dim oDerivedAssem As DerivedAssemblyDefinition
Set oDerivedAssem = oPartCompDef.ReferenceComponents. _
DerivedAssemblyComponents.CreateDefinition(Filename)
oDerivedAssem. ????????
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
xiaodong_liang
Autodesk Support
Autodesk Support
In theory,  if the associative flag is unchecked, the ActiveDesignViewRepresentation should return a null string. And setting a null string to ActiveDesignViewRepresentation should uncheck the flag. If putting ActiveDesignViewRepresentation with a not-null string, the associative flag should be checked. Hope this helps.
Jef_E
@xiaodong_liang i'm also having this issue when creating a derived assembly. I attached my code, hope that this gives a clear image of what happens. (I know that this an older topic but didn't saw any reason to start a new.)
When i run my code, it creates a new part with a derived assembly component in it. The view is pointing to "Simple" but associative flag is unchecked?
        Dim oPartDef As PartComponentDefinition
        oPartDef = oPartDoc.ComponentDefinition
        Dim oDerivedAssemblyDef As DerivedAssemblyDefinition
        oDerivedAssemblyDef = oPartDef.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(oDoc.FullDocumentName)
        oDerivedAssemblyDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsSingleBodyWithSeams
        oDerivedAssemblyDef.ActiveDesignViewRepresentation = "Simple"
        oDerivedAssemblyDef.ReducedMemoryMode = True
        Dim oDerivedAssembly As DerivedAssemblyComponent
        oDerivedAssembly = oPartDef.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAssemblyDef)
Here is a screenshot of my result using: Autodesk Inventor 2014 SP2
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
HideoYamada
I encountered this problem now. It's too bad...
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
HideoYamada
I've posted to the idea forum.
DerivedAssemblyDefinition must have IsAssociativeDesignView Property
Please vote for this if you agree.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
