Deleting Sub-assemblies using ilogic
Message 1 of 11
I am needing help writing some code to delete sub-assemblies using ilogic based on excel parameters. I have been able to write code to delete features and components out of sheet metal parts but can't seem to figure out how to do it in an assembly. I figured out how to suppress a sub-assembly but that doesn't really do me much good. I am very new to ilogic and any help would be very much appreciated.
Replies (10)
Message 2 of 11
FINET_Laurent
Can you give few more dedails regarding the actual iussue and the goal ?
It is a bit confusing (in my opinion)..
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 11
I guess basically I have an assembly within an assembly and am trying to delete it using an if/else statement in iLogic.
Message 4 of 11
FINET_Laurent
If "Magic" = True Then
	Dim CompOcc As ComponentOccurrence = Component.InventorComponent("Sub assembly:1")
		CompOcc.Delete
End If
FINET L.
Message 5 of 11
Thanks for the help. I tried the code but I keep getting an error with it saying "The parameter is incorrect". I did try the exact same code but changed CompOcc.Delete to CompOcc.Suppress and it suppress the sub-assembly. For some reason .Delete doesn't delete them.
Message 6 of 11
FINET_Laurent
Weird.. =)I'm using Inventor 2019 and it works fine with delete.
Anyway, glad I could help.
FINET L.
Message 7 of 11
J-Camper
Here is a way to do it by letting the user pick.  It could be modified to look for a particular name to automatically delete if you want:
Dim ocList As New List(Of String)
For Each oc As ComponentOccurrence In ThisApplication.ActiveDocument.ComponentDefinition.Occurrences
	If oc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then ocList.Add(oc.Name)
Next
Dim Selection As String = InputListBox("", ocList, ocList.Item(0), Title := "Item to Remove", ListName := "Sub Assemblies")
If IsNothing(Selection) Then Exit Sub 'No selection made
ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.ItemByName(Selection).Delete
Let me know if you have any questions, or if it is not working as intended
Message 8 of 11
I tried it out, but it gave me a"Member Not Found" error. I also would need to modify it to run off an if/else statement, because the people using the program wouldn't know what to do. I appreciate your help.
Message 9 of 11
Hello @Anonymous . What would be the basis or th condition of deleting the sub-assembly? Is it going to be based on filename, iproperties, etc.
Here is the rule that will delete sub-assembly if the filename contains certain string.
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
Key = InputBox("DELETE SUB-ASSEMBLY WITH THE FILENAME THAT CONTAINS", "DELETE SUB-ASSEMBLY WITH THE FILENAME THAT CONTAINS", " ").ToLower
Dim asmDef = asmDoc.ComponentDefinition
For Each occ As ComponentOccurrence In asmDef.Occurrences
	occName = occ.Name.ToLower
	If occName.Contains(Key)Then
		occ.Delete
	End If
Next
Message 10 of 11
The way i was seeing it would be like:
If option1 = 1 then  delete "TLHO3" and it's Patterns
Message 11 of 11
J-Camper
I see, so you want to delete the Patterns of a particular PatternElement Occurrence?  There is a lot to consider at each step, will there be multiple occurrences per PatternElement or does each occurrence that gets patterned have it's own set of Patterns?
The Code below will collect all parent patterns of a selected occurrence and deletes them [It does not check to see if multiple occurrences were patterned in the same ComponentPattern]:
Sub Main
Next
'Use from here down with your desired Occurrence:
Dim selOcc As ComponentOccurrence = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.ItemByName(Selection)
Dim pFeature As Object = selOcc.PatternElement.Parent
If selOcc.IsPatternElement
	Dim Col As ObjectCollection = FindTopMostParent(selOcc)
	Dim i As Integer = Col.Count
	While i > 0
		Col.Item(i).Delete
		i = i-1
	End While
End If
selOcc.Delete
End Sub
Function FindTopMostParent(Oc As ComponentOccurrence) As ObjectCollection
	Dim Result As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	Dim level1 As OccurrencePattern = Oc.PatternElement.Parent
LoopHere :
	Result.Add(level1)
	If level1.IsPatternElement
		level1 = level1.PatternElement.Parent
		GoTo LoopHere
	End If
	Return Result
End Function
