Deleting all dimensions on a specific view
marcelocar10
marcelocar10
I want delete all dimensions on a specific view. I using a rule that remove all dimensions on a sheet (as showed below), but I need remove only on a view. What is the change I need to make to the rule?
ActiveSheet = ThisDrawing.Sheet("A3:1")
Dim oSheet As Sheet = ThisDoc.Document.ActiveSheet
Dim oView As DrawingView = ActiveSheet.View("FRONTAL").View
Dim oDoc As Document =oView.ReferencedDocumentDescriptor.ReferencedDocument
'REMOVE DIMENSIONS
Dim oDim As DrawingDimension
For Each oDim In oSheet.DrawingDimensions
    oDim.Delete
Next 'Dim
FINET_Laurent
Maybe try using the pick command. There is a filter for drawing views.
ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, message)
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
marcelocar10
I can´t use the pick command, because there aren´t designer interaction. Although I have tested this way and haven´t worked very well because occur the trouble below.
Below the updated code with pick command.
ActiveSheet = ThisDrawing.Sheet("AO:1")
Dim oView As DrawingView = ActiveSheet.View("A").View
oDrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view.")
'REMOVE DIMENSIONS
For Each oDim In oDrawingView.DrawingDimensions
    oDim.Delete
Next 'Dim
Isn´t there a different command that work automatically?
JhoelForshav
Hi @marcelocar10
It's a bit tricky to find the dimensions of a view because dimensions doesn't actually belong to a view, they belong to the sheet. So there's not way to find the dimensions through the view object...
I rewrote the function from here a bit to use for this:
https://adndevblog.typepad.com/manufacturing/2012/08/how-to-determine-which-drawing-dimensions-belon...
See if it works for you 🙂
Sub Main
Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Pick view")
For Each oDim As GeneralDimension In GetDrawingDimForView(oView)
	oDim.Delete
Next
End Sub
Function GetDrawingDimForView(oView As DrawingView) As ObjectCollection
  Dim oDrawDimsForView As ObjectCollection
  oDrawDimsForView = ThisApplication.TransientObjects.CreateObjectCollection
  Dim oDrawDims As DrawingDimensions
  oDrawDims = oView.Parent.DrawingDimensions
  Dim oDrawDimIterator As DrawingDimension
  For Each oDrawDimIterator In oDrawDims
    Select Case oDrawDimIterator.Type
      Case kLinearGeneralDimensionObject
        Dim oLinearDim As LinearGeneralDimension
        oLinearDim = oDrawDimIterator
        If oLinearDim.IntentOne.Geometry.Parent Is oView Then
          oDrawDimsForView.Add(oDrawDimIterator)
        End If
      Case kRadiusGeneralDimensionObject
        Dim oRadiusDim As RadiusGeneralDimension
        oRadiusDim = oDrawDimIterator
        If oRadiusDim.Intent.Geometry.Parent Is oView Then
        End If
      Case kDiameterGeneralDimensionObject
        Dim oDiameterDim As DiameterGeneralDimension
        oDiameterDim = oDrawDimIterator
        If oDiameterDim.Intent.Geometry.Parent Is oView Then
        End If
      Case kAngularGeneralDimensionObject
        Dim oAngularDim As AngularGeneralDimension
        oAngularDim = oDrawDimIterator
        If oAngularDim.IntentOne.Geometry.Parent Is oView Then
        End If
      Case Else
        'Case is not handled...
    End Select
  Next
  GetDrawingDimForView = oDrawDimsForView
End Function
marcelocar10
Hi @JhoelForshav ,
Thank you for your help. This rule work very well, but it only deletedthe dimensions that were entered manually in drawing. The dimensions that were entered in a view by command (like showed bellow) have not been deleted.
'Example way to insert a dimension
Dim oDim1 As GeneralDimension = oSheet.DrawingDimensions.GeneralDimensions.AddLinear(textPoint, oGeomIntent1, oGeomIntent2, DimensionTypeEnum.kVerticalDimensionType)
I tryed to change the "kLinearGeneralDimensionObject" for the "kGeneralDimensionObjetc" in one of the function's cases (like example below) but don't worked.
       Case  kGeneralDimensionObject
        Dim oGeneralDim As GeneralDimension
        oGeneralDim = oDrawDimIterator
        If oGeneralDim.IntentOne.Geometry.Parent Is oView Then
        End If
Can you help me update the rule to delete this dimension type?
JhoelForshav
Hi @marcelocar10
The dimension in your example is in fact an object of type kLinearGeneralDimension, so that's not the problem. The reason it doesn't work is because you have used an object as IntentOne that doesn't have the drawingview as it's parent property. What did you use as IntentOne here?
Anyways, I think maybe this approach will be better for you. I create a box around the view in question and delete every dimension that has its intentpoint inside that box. Try it and see how its better 🙂
Sub Main
	Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Pick view.")
	Dim oCol As ObjectCollection = GetDimsFromView(oView)
	For Each oDim As GeneralDimension In oCol
		oDim.Delete
	Next
End Sub
Function GetDimsFromView(oView As DrawingView) As ObjectCollection
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oBox As Box2d = oTG.CreateBox2d
	oBox.MaxPoint = oTG.CreatePoint2d(oView.Center.X + oView.Width / 2, oView.Top)
	oBox.MinPoint = oTG.CreatePoint2d(oView.Center.X - oView.Width / 2, oView.Top - oView.Height)
	oBox.Expand(0.001)
	Dim oDrawDimsForView As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	Dim oSheet As Sheet = oView.Parent
	For Each oDrawDimIterator As GeneralDimension In oSheet.DrawingDimensions.GeneralDimensions
        If oBox.Contains(oLinearDim.IntentOne.PointOnSheet) Then oDrawDimsForView.Add(oDrawDimIterator)
        If oBox.Contains(oRadiusDim.Intent.PointOnSheet) Then oDrawDimsForView.Add(oDrawDimIterator)
		If oBox.Contains(oDiameterDim.Intent.PointOnSheet) Then oDrawDimsForView.Add(oDrawDimIterator)
		If oBox.Contains(oAngularDim.IntentOne.PointOnSheet) Then oDrawDimsForView.Add(oDrawDimIterator)
      Case Else
    End Select
	Next
	Return oDrawDimsForView
End Function
marcelocar10
Hi @JhoelForshav ,
Ok, now I get it. The last solution worked perfectly. Thank you very much for your attention.
Regards
