Delete, move and move and delete from one folder to a new one.
CCarreiras
Mentor Mentor
CCarreiras
HI!
I found some peaces of code, and i believe is possible to do what i need.
I need something like that:
I have already folders, where I save files converted from Inventor dwg to pdf and dwg acad and dxf
workspace &”\dxf”
workspace &”\dwg”
This work fine.
What I need is.
When I create a new parametrization, to have the possibility to fire a rule (clicking in a button in a form for ex.), to ask the user what to do with previous files in that folders (if they exist)… delete, move to a new folder, or move and delete.
In case "move (like copy/paste) or move and delete (like cut/paste)" asking for destination folder and create that folder is a good feature...
For now, after any new parametrization, the user must remember that have to clean the folders after create new pdf or dwg.
Something like this_________check if exist files in folder and what tro do with them
Try
		If System.IO.File.Exists(aExist) = True Then
			Select Case UCase(Action)
			Case "D"
				System.IO.File.Delete(oLocation)
			Case "M"
				System.IO.File.Move(aExist, oLocation)
			Case "DM"
			End Select
		End If
More this__________Ask for a folder and save  it in the new folder.
Imports System
Imports System.Diagnostics
Imports System.Threading
Imports System.Windows.Forms
Sub Main()
oFolder = oFolderDlg
r= MsgBox(oFolder & " was selected" &vbLf & vbLf & "Proceed?", MsgBoxStyle.YesNo,"iLogic")
If r = MsgBoxResult.No
Exit Sub
End If
Thank you.
CCarreiras
rossano_praderi
Hi Carlos,
I would like to give you a starting code for your request
Imports System
Imports System.Drawing
Imports System.IO
Sub Main
		'MultiValue.SetList("Choice", "Delete", "Move", "Move/Delete")
	Choice = InputListBox("Prompt", MultiValue.List("Choice"), Choice, Title := "Title", ListName := "List") ' Choice is an user parameter
	Select Case Choice
		Case "Delete"
			' your code here
		Case "Move"
			' your code here
		Case "Move/Delete"
			' your code here
	End Select
	MsgBox(fBrowser)
End Sub
Private Sub OnAllFiles(Action As String, sourceDir As String, DestDir As String)
Try
	Dim FileList As String() = System.IO.Directory.GetFiles(sourceDir, "*.*")
	DestDir = fBrowser()
	Select Case Action
		Case "D"
			For Each f As String In FileList
				System.IO.File.Delete(f)
			Next
		Case "M"
				System.IO.File.Move(f, DestDir)
			Next
	End Select
Catch dirNotFound As DirectoryNotFoundException
	MsgBox(dirNotFound.Message)
End Try
End Sub
Private Function fBrowser() As String
Dim nDialog as New FolderBrowserDialog
Dim result As DialogResult = nDialog.ShowDialog()
     If ( result = DialogResult.OK  And nDialog.SelectedPath IsNot Nothing) Then
		fBrowser = nDialog.SelectedPath
	Else
		fBrowser = "NO FOLDER SELECTED"
	End If
End Function
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
