Hi Kenny,
The first thing I would do when using it is back up your files. I would also make a third copy that you run this on specifically to test that this does what you are looking for.
First step to use it is to unzip the files. I imagine windows has a built in tool for this, if not google should show you how to do this without too much trouble. The file you want to use is called DeleteRules.exe in the root of the zip.
To use it you should execute it from the command line. To do this go to Run in the start menu and type cmd. You can also get to it from Start -> Accessories -> Command Prompt
You should see a black screen with something line:
C:\Documents and Setting\Kenny>
From here you need to write 3 things seperated by spaces:
- The path of DeleteRules.exe that you downloaded
- The location of the folder containing the files that you want the rules deleted from
- The extension of the files you want to delete the rules from
For example lets say you extracted that zip to C:\Documents and Setting\Kenny\Downloads\TheZip and you keep all your inventor files that you want to delete the rules from in C:\Documents and Setting\Kenny\Work\SomeProject and in this particular case you only want to delete the rule "rule0" from your part files (not assemblies or other inventor file) you would type:
C:\Documents and Setting\Kenny\Downloads\TheZip\DeleteRules.exe C:\Documents and Setting\Kenny\Work\SomeProject rule0 .ipt
This will delete any rules called rule0 from any .ipt file in the SomeProject directory (and any sub-directories). With the Vault directory structure, it soulds like you should point it to the parent folder of the 14000, 15000, etc folders which will cover all the sub folders (This will remove the rule from every part in these folders though). If you wanted to do delete rule0 from both parts and assemblies but only from the subfolder 15000 you would use:
C:\Documents and Setting\Kenny\Downloads\TheZip\DeleteRules.exe C:\Documents and Setting\Kenny\Work\SomeProject\15000 rule0 .ipt .iam
For rules with different names you will need to rule that command once per rule with rule0 changed to whatever your rule is called.
Let me know if I have explained this ok and if this cover's what you are looking for. If this isn't what you need I might have a look at it changing it to be more appropriate tonight. I haven't used inventor since about the time I wrote the last post though so I won't promise anything.
Sincerely,
Brent Douglas
