Delete Drawing Sheets
CadUser46
CadUser46
Im trying to delete all drawing sheets and leave only the first page.  I have this so far but it fails after the first time it deletes the last sheet.
I think i have to tell it to re-count the sheets before going back into the for next loop but i dont know how to.
Sub ObsoleteDrawing()
If ThisApplication.ActiveDocument Is Nothing Or ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
MsgBox ("Please open a drawing to obsolete")
End If
Dim oDoc As Inventor.DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheets As Sheets
Set oSheets = oDoc.Sheets
Dim i As Integer
i = 1
Dim oSheet As Sheet
Set oSheet = oSheets.Item(i)
oSheet.Activate
    For i = 1 To oDoc.Sheets.Count
        If i > 1 Then
        oSheet.Delete
        End If
    Next
End Sub
Inventor 2010 Certified Professional
Currently using 2023 Pro
YuhanZhang
You can try below Do ... Loop instead of the For ... Next:
      Do While oDoc.Sheets.count > 1
        Set oSheet = oDoc.Sheets.Item(oDoc.Sheets.count)
        oSheet.Delete
      Loop
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
