Deactivate add-in with vba or vb.net
GeorgK
Advisor Advisor
GeorgK
Hello together,
how can I deactivate an add-in with vba or vb.net?
Thank you
Georg
Hi Georg,
Here a VB.Net example with iLogic:
First, I create a module for the ItemByName extension (if you don't familiar with extension, read about it, it's a nice way of programming).
Public Module InventorExtensions
    <Extension()> _
    Function ItemByName(applicationAddIns As Inventor.ApplicationAddIns, displayName As String) As Inventor.ApplicationAddIn
        For Each i As Inventor.ApplicationAddIn In applicationAddIns
            If i.DisplayName = displayName Then
                Return i
            End If
        Next
        Return Nothing
    End Function
End Module
Next, add this to your method:
Dim inventorApplication as Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
Dim iLogic as Inventor.ApplicationAddIn = InventorApplication.ApplicationAddIns.ItemByName("iLogic")
iLogic.Deactivate
 Give me feedback if it's what you need.
Pascal
I forgot this line of code:
   Imports InventorExtensions
Put this on the top of your document where your method is.
Pascal
GeorgK
Hello Pascal,
thank you very much.
Georg
Hi Georg,
To turn off addins before invetor starts, you need to fettle with the registry entries. To do this, you need to create a new class and add the following code:
Imports Microsoft.Win32
Public Class RegistryEntry
    Public Sub ChangeRegistryKey(ByVal strMainKey As String, ByVal StrOn As String)
        'MessageBox.Show("CLSID\{" & strMainKey & "}\Settings", "")
        Dim Autoshell As RegistryKey = My.Computer.Registry.ClassesRoot.OpenSubKey("CLSID\{" & strMainKey & "}\Settings", True)
        If Autoshell Is Nothing Then
            'Registy key does not exit - do nothing
        Else
            Autoshell.SetValue("LoadOnStartUp", StrOn)
            Autoshell.Close()
        End If
    End Sub
End Class
Then you need to find the registry key you want to change - a simple search through the registry for the name of the addin will get this.
Then, add the following lines of code to your program before you start inventor:
Dim AssemblyBonusTools As New RegistryEntry
AssemblyBonusTools.ChangeRegistryKey("0BB5AE99-15A3-4B00-9731-210ED5A4E7B2", 0/1)
The 0/1 element is a string I believe, but don't quote me on this.
Don't forget to turn any addins back on again once you've finished.
Hope this is of some use to you.
Jon
