Cycle ThisDoc.Document.SaveAs iLogic
flyingdelorean.ru
flyingdelorean.ru
Why does this ilogic code not work?
Dim FileName As String
For i As Integer = 1 To 10
	FileName = ThisDoc.Path & "\" & "VertY" + i.ToString + ".ipt"
ThisDoc.Document.SaveAs(FileName, True)
Next
 I want to save the same file 10 times with different names
dutt.thakar
@flyingdelorean.ru
It is working, what is it that is not working for you? Do you get any error messages? See below GIF, which shows it is working.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
flyingdelorean.ru
  Probably because of the need to overwrite existing files
