Calculate mass
Calculate mass
bernd.schreck
Calculate mass
bernd.schreck
hope I´m in the right forum.
I want to update the mass of a part (or assembly) from an Inventor Addin.
Using Inventor 2020 and VB.net
Problem is that I want to update/calculate the mass which was changed by the user (so a "custom" mass) based on the selected material.
Already looked in the forums but the following solutions does not working:
'updating mass by instancing
Dim dMass As Double
dMass = oDoc.ComponentDefinition.MassProperties.Mass
'updating mass by using controls
Dim CmdMan As ControlDefinition
CmdMan = invApp.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd")
'CmdMan.Execute()
CmdMan.Execute2(True)
The mass stays always at the custom one which the user first has defined.
In Inventor I could press the update button after removing the mass, but how to solve this by API?
THX
Bernd
dutt.thakar
@bernd.schreck
Are you looking for something like this? This will check if the mass is overridden, if it is, it will remove it and update the iProperties. I tested it and it is working as expected.
Dim oDoc As PartDocument = invApp.ActiveDocument
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
If oDef.MassProperties.MassOverridden = True
	oDef.MassProperties.MassOverridden = False
invApp.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
 Hope this will help.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
bernd.schreck
Exactly what I have looked for.
Thank you so much @Anonymous.hakar 🙂
