Custom Sheet Metal Unfold Equation
I am a new user switching over from NX.  My question relates to the sheet metal unfold custom equations settings.  I have been using a custom equation in NX that has been working very well for our sheet metal parts, but I can't get Inventor to accept the equation.
Going to "Sheet Metal Defaults" > the pencil icon to edit > changing the unfold method to "Custom Equation" > double clicking in the custom equation field.
The first screen grab shows the equation I want
The second screen grab shows that the equation, before adding the bend angle, works (black text).
Does anyone no what syntax or other error I am making on this?
Thanks in advance,
K
The output of the equation should be in mm.
Therefore try replacing 'β' with '(β/180 deg)*π', which is unitless.
For more information check:
http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-715EE575-76F0-456A-BEC1-48D3401C9255
