I'm not completely sure what you want the end result to look like. (I guessed that the image shows the sketch not the end result.) But I think that this rule will do more or less what you want and I hope it's easy enough to change it.
Public Sub main
Dim view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a View")
Dim sketch As DrawingSketch = view.Sketches.Add()
Dim cp = sketch.SheetToSketchSpace(view.Position)
Dim blue As Color = ThisApplication.TransientObjects.CreateColor(0, 0, 255)
Dim offSetFromView As Double = 1
sketch.Edit()
Dim lines = CreateRectangle(sketch, cp, view.Width + offSetFromView, view.Height + offSetFromView)
SetLayer(lines, LineTypeEnum.kDashedLineType, 0.05, blue)
sketch.ExitEdit()
End Sub
Public Sub SetLayer(lines As SketchEntitiesEnumerator, LineType As LineTypeEnum, LineWeight As Double, color As Color)
For Each line As SketchEntity In lines
Line.Layer.LineType = LineTypeEnum.kDashedLineType
Line.Layer.LineWeight = LineWeight
Line.Layer.Color = color
Next
End Sub
Public Function CreateRectangle(Sketch As DrawingSketch, cp As Point2d, w As Double, h As Double) As SketchEntitiesEnumerator
Dim oTg = ThisApplication.TransientGeometry
Dim p1 As Point2d = cp.Copy()
p1.TranslateBy(oTg.CreateVector2d(w / 2, h / 2))
Dim p3 = p1.Copy()
p3.TranslateBy(oTg.CreateVector2d(-w, -h))
Dim lines = Sketch.SketchLines.AddAsTwoPointRectangle(p1, p3)
Return lines
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
