Custom Poperty Format Precision
How do I setup the precision of a Custom Property ?
I tried several codes from the forum, but non of them works and on Inventor Helps I didn't find anything.
Thank you in advance !
pball
Here is some VBA code that can change the precision of parameters
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveEditDocument
    Dim oParameter As Parameter
    For Each oParameter In oPartDoc.ComponentDefinition.Parameters
'Set as exported oParameter.ExposedAsProperty = True
'Set type oParameter.CustomPropertyFormat.PropertyType = kTextPropertyType
'Set units oParameter.CustomPropertyFormat.Units = UnitsTypeEnum.kInchLengthUnits
'Set precision and decimal/fraction oParameter.CustomPropertyFormat.Precision = kThreeDecimalPlacesPrecision
'Show units string oParameter.CustomPropertyFormat.ShowUnitsString = True Next oParameter
Values for precision
kZeroFractionalLengthPrecision
kHalfFractionalLengthPrecision
kQuarterFractionalLengthPrecision
kEighthsFractionalLengthPrecision
kSixteenthsFractionalLengthPrecision
kThirtySecondsFractionalLengthPrecision
kSixtyFourthsFractionalLengthPrecision
kOneTwentyEighthsFractionalLengthPrecision
kZeroDecimalPlacePrecision
kOneDecimalPlacePrecision
kTwoDecimalPlacesPrecision
kFourDecimalPlacesPrecision
kFiveDecimalPlacesPrecision
kSixDecimalPlacesPrecision
kSevenDecimalPlacesPrecision
kEightDecimalPlacesPrecision
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
GeorgK
Private Sub Test()
Dim oInvApp As Application
Set oInvApp = ThisApplication
Dim oUserParameter As UserParameter
Set oUserParameter = oInvApp.ActiveDocument.ComponentDefinition.Parameters.UserParameters.Item(1)
oUserParameter.ExposedAsProperty = True
oUserParameter.CustomPropertyFormat.PropertyType = CustomPropertyTypeEnum.kTextPropertyType
oUserParameter.CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kTwoDecimalPlacesPrecision
oUserParameter.CustomPropertyFormat.Units = UnitsTypeEnum.kMillimeterLengthUnits
oUserParameter.CustomPropertyFormat.ShowUnitsString = False
End Sub
