Custom Material Library not up-dating globally
DonCMorrison
DonCMorrison
I created a custom material library and added it to my project files.   It is now available as the default library.   It does not up-date the library when  I add a new material to a part.   I have been duplicating a similar material and then renaming it and revising the properties.   The new material only seems to be available to the part open when I added it.   How can I get it to up-date the library so that it is available to all parts?
Darkforce_the_ilogic_guy
I thing you need add it to the Library and save the style (under the Stales and Standrds tabs
