Custom iProperty and BOM Export
Jason.Rugg
Jason.Rugg
For estimating purposes we need to be able to export a BOM to excel spreadsheet that includes a column that has lengths. We can currently do this but would like to automate it. Currently all parts have a G_L custom iproperty for lengths, to get this into the BOM we have to manually add the G_L property to the assembly level and then we are able to add the G_L column in the BOM to be able to export our lengths to a spreadsheet.
I would like a single rule that would automatically add the G_L custom iproperty to an assembly model if it doesn't exist and then add that column to the BOM and then export/save the BOM (structured/all levels) to a spreadsheet in a desired location.
JelteDeJong
the easiest way I can think of is to create a "Bom customization file" after you have done all your settings manualy
and then import that file and export like this
Dim BomSettingsFile As String = "C:\temp\BomSettings.xml"
Dim BomFile As String = "C:\temp\bom.xlsx"
Dim doc As AssemblyDocument = ThisApplication.ActiveDocument
Dim bom As BOM = doc.ComponentDefinition.BOM
bom.ImportBOMCustomization(BomSettingsFile)
bom.BOMViews.Item("Structured").Export(BomFile, FileFormatEnum.kMicrosoftExcelFormat)
Jelte de Jong
Blog: hjalte.nl - github.com
Jason.Rugg
@JelteDeJong Looks like that will get the export done for the spreadsheet but is there a way to get the rule to add the G_L custom iproperty to the assembly file if it doesn't exist?
JelteDeJong
if you export the settings file after you added the G_L custom property column it will be in the settings file. Then when the rule imports the settings also the property will automatically be added.
Jelte de Jong
