Custom Iproperties reading value using ilogic problem
infoEHE7X
infoEHE7X
The code below has no issue as I have used it for taking value of other iproperties, however for the custom iproperties it cannot detect the corresponding value from the attached file.
Imports System.IO
Imports System.Windows.Forms
Sub Main()
' Get the assembly file path from the user
Dim assemblyFilePath As String = GetFilePath("Select the assembly file", "Assembly Files (*.iam)|*.iam")
If assemblyFilePath = "" Then
MsgBox("No assembly file selected.")
Exit Sub
' Open the selected assembly file
Dim asmDoc As AssemblyDocument = ThisApplication.Documents.Open(assemblyFilePath)
' Define the custom property names to retrieve
Dim propertyNames As String() = {"MARK", "QTY", "SERVICE"}
' Fetch and display each custom iProperty
Dim result As String = "Custom iProperty Values for Assembly:" & vbCrLf
For Each propName As String In propertyNames
Dim value As String = GetiPropertyValue(asmDoc, propName)
result &= propName & ": " & value & vbCrLf
Next
' Show the result to the user
MsgBox(result, MsgBoxStyle.Information, "Custom iProperties")
End Sub
' Function to retrieve the custom iProperty value
Function GetiPropertyValue(oDoc As Document, propertyName As String) As String
Try
Return CStr(iProperties.Value("Custom", propertyName))
Catch ex As Exception
Return "N/A"
End Try
End Function
' Helper function to get file path
Function GetFilePath(prompt As String, filter As String) As String
Dim openFileDialog As New OpenFileDialog()
openFileDialog.Title = prompt
openFileDialog.Filter = filter
If openFileDialog.ShowDialog() = DialogResult.OK Then
Return openFileDialog.FileName
Return ""
End Function
Michael.Navara
This can be because iLogic iProperties object returns properties from the document in which context the rule is running. Try to use standard API for iProperties in this case.
Sub Main()
        Exit Sub
    Next
End Sub
    'Try
    '    Return CStr(iProperties.Value("Custom", propertyName))
    'Catch ex As Exception
    '    Return "N/A"
    'End Try
    Try
        oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")(propertyName).Value.ToString()
        Return "N/A"
    End Try
End Function
    Return ""
End Function
Note: Please use code snippet block for code samples. It is much more readable. 😀
infoEHE7X
Thanks Michael, Here is the clean code:
Imports System.IO
Sub Main()
        Exit Sub
    Next
End Sub
    Try
        ' Access the "Inventor User Defined Properties" property set
        Dim customPropertySet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
        Dim propValue As Object = customPropertySet.Item(propertyName).Value
        If propValue IsNot Nothing Then
            Return propValue.ToString()
        ' If the property does not exist, return "N/A"
    End Try
    Return "N/A"
End Function
    Return ""
End Function
