Changing ViewAnnotation Style
anita_zhangBRAD8
Message 1 of 8
anita_zhangBRAD8
I am struggling with changing the ViewAnnotation Style. I can successfully locate and access the desired style but I couldn't find an approach to apply it to my drawing view (oView2).
I saw a few posts from 2018/2019 saying ViewAnnotationStyle is not exposed in Inventor API.
Does anyone know if changing ViewAnnotationStyle is supported in Inventor now? If so, how can I set it?
Thank you so much for the help!
	Dim oView2 As DrawingView
	oView2 = oSheet.DrawingViews.AddSectionView(oView1, oSectionSketch, oPoint2, kFromBaseDrawingViewStyle, oView1.Scale, True, "A")
	Dim annotationStyle As Inventor.Style
	annotationStyle = oStylesMgr.Styles.Item("Custom View Annotation (ISO)")
	MsgBox(annotationStyle.Type.ToString)    ---- this prints out Style Object
Replies (7)
Message 2 of 8
JMGunnar
explian more
its there label text you looking for ?
oView2.label.textstyle
best JG
oView2
Message 3 of 8
anita_zhangBRAD8
Hi JG, thank you for your reply. I meant the whole format of a section line such as the section arrow, text style. Here is the screenshot of my custom style.
I've tried to change the view label style, but the result was not what I expected.
Message 4 of 8
JMGunnar
Do you only wont too  apply  ViewAnnotation Style too  one "view2"
or  you can set Object default standard
Best Regards Johan
Message 5 of 8
anita_zhangBRAD8
Hi Jonan. Yes I only want to change "view2".
I've tried setting object defaults too. I successfully set other style such as parts list style using object defaults. But according to the link here: Inventor 2024 Help | ObjectDefaultsStyle Object | Autodesk, there are not any methods about view annotation style, or section line style. So I doubt Inventor API supports this functionality now.
Message 6 of 8
JMGunnar
 about view annotation style not supporting in API
like you alread know.
why do you only want too change view2 ???
can you post one picture one the view you want too change ?
Best Regards Johan
Message 7 of 8
anita_zhangBRAD8
Hi Johan, yeah for sure.
Here is the original style:
Here is the expected style:
I want to change the style of section line A only, it's just a client request.
Message 8 of 8
anita_zhangBRAD8
Yeah, from my research from the internet, it seems like there's no way to directly change viewannotation style for now. Is there anyway to change the parameters of standard style applied to that section line?
