Custom Hole Note and Tolerances Automatically assigned based on Hole Type
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So, I know how to create and Edit hole notes, I am wondering if any iLogic or VBA exists that detects the hole "type" and can accordingly assign a specific hole note (specifically for me, tolerances based on type.)
Internally, I have edited our hole/thread table file and added "dowel Pin holes". (We were having trouble getting 12 engineers to use the same dimensions based on the dowel pins - we'll leave it at that). As you can see in the image, When I select fastener type, I have the option of "Dowel Pin Hole". You then select a nominal size. (Shown here as M2).
A CLOSE hole is 2.00, a NORMAL hole is 2.025, and a LOOSE hole is 2.050.
When I go into the drawing, I would like to be able to apply hole notes that automatically assign the dimension with a specific tolerance, rather than have to edit the note for every down pin hole I call out. I.E. a CLOSE hole is X.XX+0.0/-0.025, NORMAL hole is X.XX+0.025/-0.00, and LOOSE hole is X.XX+0.025/-0.00. I don't want to have to always go up in my Annotate Tab and select the Style in the Format menu, since I can't tell by looking at the hole what type it is until after I apply the hole note.
