Custom fonts
Custom fonts
daniele.galliano
Message 1 of 8
Custom fonts
daniele.galliano
why do not export a custom font with command "export pdf"
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hello @daniele.galliano,
Are you trying to achieve "export pdf" through Inventor API?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
daniele.galliano
Thanks for your support, but what's API? Maybe Autodesk Professional
Inventor?
I'd like to get pdf with this command in Autodesk Professional Inventor
2018.
Message 4 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@daniele.galliano,
Can you please ask the same question at "Inventor Forum" using below link?
https://forums.autodesk.com/t5/inventor-forum/bd-p/78
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 8
daniele.galliano
Thanks for your support, but what's API? Maybe Autodesk Professional Inventor?
I'd like to get pdf with this command in Autodesk Professional Inventor 2018.
menu file/export/pdf
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
For more details about Inventor API, go through the following link.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-4939ABD1-A15E-473E-9376-D8208EC029EB
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 8
daniele.galliano
Yes, I tried both with the menu commant export to pdf and API by an addin written in Visual Basic, but the result is the same our custom font
is not printed correctly.
Only with PDF Creator as printer I obtain the correct font, but I need to do this with API.
Message 8 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Can you please provide sample drawing with custom font to test?
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
