Curve Length as Reference Parameters in Rectangular Pattern
kresh.bell
Message 1 of 8
kresh.bell
I first tried to solve this problem on the general discussion forum, but I was instructed to try here anyway.
I have an adaptive part.
Does anyone know how I can use curve Length value from the Pattern feature for some other feature or as a linked value?
This value does not exist in Reference Parameters, nor is it in Model Parameters and User Parameters, but that curve length exists, the value is also displayed in gray.
Is it possible to use that length with iLogic?
Replies (7)
Message 2 of 8
dalton98
Hello. I messed around with it for a bit and what I think your after is the X/Y 'DirectionEntity'. The problem however is the edge can be overridden if it is part of the pattern. In that case you will have half the value. So ideally you would need to create a separate sketch to pattern off of.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oRPF As RectangularPatternFeature = _
oDoc.ComponentDefinition.Features.RectangularPatternFeatures(1)
Dim oEdge As Edge = oRPF.Definition.XDirectionEntity
oEdge.Evaluator.GetParamExtents(MinParam, MaxParam)
MessageBox.Show(MaxParam - MinParam)
Message 3 of 8
kresh.bell
I didn't quite understand you, but when I run your iLogic I get this
Message 4 of 8
dalton98
What is the Direction or 'Curve Length' based off of? I was assuming it was an Edge. It is some kind of GeometryIntent then since the other options dont have a 'Curve Length'
Maybe try searching for its ObjectType
MessageBox.Show(oRPF.Definition.XDirectionEntity.Type.ToString)
Message 5 of 8
dalton98
Ok it would probably look something more like this
Dim oPath As Path = oRPF.Definition.XDirectionEntity
Dim oLine As LineSegment = oPath(1).Curve
MessageBox.Show(ThisApplication.MeasureTools.GetMinimumDistance(oLine.StartPoint, oLine.EndPoint))
'oLine.Evaluator.GetParamExtents(MinParam, MaxParam)
'oLine.Evaluator.GetLengthAtParam(MinParam, MaxParam, oLength)
'MessageBox.Show(oLength)
Message 6 of 8
kresh.bell
something is wrong
Most likely, I did not explain well.
I have an assembly that I use as a template for iCopy (see attch). Everything works ok. But I have a "quantity" parameter. The problem starts when I want to add to that assembly parts that I want to duplicate with the pattern feature.
Message 7 of 8
dalton98
We're still using Inventor 2022 so I cant view it. The length has to be based off something though, cant you just find that line/curve and dimension it to make a parameter then link that parameter value?
Sorry if I'm not understanding, havn't worked with iCopy before.
Message 8 of 8
t_fransman
This should automatically make a ref para. So you can use an equation to get the ... Qty Value. Above. Did you ever get an ilogic that actually works? Same problem or very similar here!
