Creating multivalue parameters in VBA
Thomas.Long
Thomas.Long
Ok, so I'm trying to shift some of my stuff over from iLogic to VBA and I'm having some issues with multivalue parameter creation. The parameter.ExpressionList.SetExpressionList function is just endlessly crashing the program. No error messages, no warnings, even the debugger won't do anything. Just boom, program gone, every single time.
I know that my function is returning a new parameter so I'm a little unsure what is going on.
Thank you
    Dim oParam As UserParameter
    Dim valList(4) As String
    valList(0) = "None"
    valList(1) = "Side A"
    valList(2) = "Side C"
    valList(3) = "Side A & C"
    Set oParam = Assembly_Functions.ParaCreation("LWSplits", "None", "Text")
    Call oParam.ExpressionList.SetExpressionList(valList)
'The ParaCreation function checks if a parameter exists and if it does not creates it with the defined type and starting value.
'The types defined for it are "Number", "Boolean", and "Text"
Function ParaCreation(sName As String, StartValue As String, oType As String) As UserParameter
    'Declaring document variables
    Dim oMyAssembly As AssemblyDocument
    Set oMyAssembly = ThisApplication.ActiveDocument
    Dim oMyParameter As UserParameters
    Set oMyParameter = oMyAssembly.ComponentDefinition.Parameters.UserParameters
    Dim oCompDef As AssemblyComponentDefinition
    Set oCompDef = oMyAssembly.ComponentDefinition
    'Create boolean for checking existence of parameter
    Dim blTag As Boolean
    blTag = False
    'Check through parameters to make sure parameter doesn't exist
    For i = 1 To oCompDef.Parameters.Count
        If oCompDef.Parameters(i).name = sName Then
            blTag = True
            Set oCompDef.Parameters(i).Value = StartValue
            Set oParam = oCompDef.Parameters(i)
            Exit For
    Next
    'Create parameter if it doesn't exist
    If blTag = False Then
        If oType = "Text" Then Set oParam = oMyParameter.AddByValue(sName, StartValue, UnitsTypeEnum.kTextUnits)
        If oType = "Number" Then Set oParam = oMyParameter.AddByExpression(sName, StartValue, "in")
        If oType = "Boolean" Then
            Dim boolValue As Boolean
            If StartValue = "True" Then
                boolValue = True
            Else
                boolValue = False
            Set oParam = oMyParameter.AddByValue(sName, boolValue, "Boolean")
    Set ParaCreation = oParam
End Function
Sergio.D.Suárez
Hi, try to run the following macro. I made some changes to your initial code.
I have tried this macro and it worked for me.
Sub Create_Parameter()
    valList(0) = """None"""
    valList(1) = """Side A"""
    valList(2) = """Side C"""
    valList(3) = """Side A & C"""
    Set oParam = ParaCreation("LWSplits", "None", "Text")
End Sub
    blTag = False
        If oCompDef.Parameters(i).Name = sName Then
            blTag = True
            Exit For
    Next
                boolValue = True
            Else
                boolValue = False
End Function
 Hope this helps to solve your problem. Cheers!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thomas.Long
Nah, I tried running it and got the same problem. It's still just crashing there.
Can I ask what version of inventor you're using? I'm on 2015. I saw that as a fix for this back in 2011 but wasn't able to get it to work
Sergio.D.Suárez
I am using inventor 2020.
Here is a video of the process on my pc
Mechanical Designer
Sergio.D.Suárez
Try the following code, in the past I have had some problems with the character ", so sometimes it is necessary for the formula that replaces the character value.
Another change placed in this code, is the complete function "SetExpressionList" with the parameters false and -1.
    valList(0) = Chr(34) & "None" & Chr(34)
    valList(1) = Chr(34) & "Side A" & Chr(34)
    valList(2) = Chr(34) & "Side C" & Chr(34)
    valList(3) = Chr(34) & "Side A & C" & Chr(34)
    Call oParam.ExpressionList.SetExpressionList(valList, False, -1)
End Sub
    blTag = False
            blTag = True
            Exit For
    Next
                boolValue = True
            Else
                boolValue = False
End Function
Mechanical Designer
Thomas.Long
I'll give it a shot tomorrow and let you know how it goes. Thank you for all the help!
Thomas.Long
Sorry, it's still causing the same crashing error
