Attach dxf to ipt via "Insert Object" and "Create from File" using iLogic
We've got 1000+ sheet metals part files we'd like to attach it's own dxf to. Manually we do this by going to Manage -> Insert Object -> Create from file -> browse to file -> check "Link" checkbox -> OK. Then after we move it to Vault, when we release the ipt, it'll automatically also release the dxf.
For the first 1000ish parts that have been migrated, this step wasn't followed. Is there a way I can do this with an iLogic rule from a large assembly where I have all the ipt's that don't have a dxf attached?
Note: ipt and dxf always have the same file name (except for the file extension of course)
JelteDeJong
I assumed that the ipt and dxf files are also in the same directory. Try this iLogic rule.
Dim doc As AssemblyDocument = ThisDoc.Document
Dim nl = System.Environment.NewLine
Dim notFOundList = "The following files where not found:" & nl
For Each refDoc As Document In doc.ReferencedDocuments
    If refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
        Dim fileName As String = refDoc.FullFileName
        fileName = fileName.Replace(".ipt", ".dxf")
        If (IO.File.Exists(fileName)) Then
            refDoc.ReferencedOLEFileDescriptors.Add(fileName, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
        Else
            notFOundList = notFOundList & fileName & nl
Next
MsgBox(notFOundList)
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you JelteDeJong! It worked perfectly right away. You've saved us so many hours. All the best!
