Creating Model States in sub-sub-assemblies prompts dialog box
ben.goodelliott
ben.goodelliott
Hi folks,
    I've been trying (and succeeding) to create model states 2 layers down from the main assembly with iLogic. However, before my rule completes, I am prompted with the message box above. I have tried forcing a save in the sub-assembly, the sub-sub-assembly, and top level assembly with no luck.
    I've looked through the forum and done several google searches without finding anything directly relevant as far as I can tell. Does anyone have any suggestions?
Ivan_Sinicyn
Here's a simple code. Select a subassembly and call the context menu to create a new Model State
Sub Main()
    ' Initialize document and events
    oDoc = ThisApplication.ActiveDocument
    oUserInputEvents = ThisApplication.CommandManager.UserInputEvents
    ' Initialize the button
    InitializeButtonDefinition()
    ' Attach the button execution handler
    AddHandler oButtonDef.OnExecute, AddressOf CreateNewModelStateHandler
End Sub
Private Sub InitializeButtonDefinition()
    Try
        Dim oControlDefs As ControlDefinitions = ThisApplication.CommandManager.ControlDefinitions
        ' Check if the button already exists to avoid duplicate creation
        Try
            oButtonDef = oControlDefs.Item("CreateModelStateBtn")
        Catch ex As Exception
            oButtonDef = Nothing
        End Try
        If oButtonDef Is Nothing Then
            ' Create a new button
            oButtonDef = oControlDefs.AddButtonDefinition("Create Model State", _
                "CreateModelStateBtn", _
                CommandTypesEnum.kShapeEditCmdType, _
                "{FB2A51F6-321A-4E6B-8F91-3A7D4E9B1234}", _
                "Creates a new model state for the selected subassembly")
        End If
        MsgBox("Error initializing the button: " & ex.Message, vbCritical, "Error")
    End Try
End Sub
' Module-level variable declarations
Dim oDoc As AssemblyDocument
Dim oSubAsm As ComponentOccurrence
Dim oModelStates As ModelStates
Dim WithEvents oUserInputEvents As UserInputEvents
Dim oButtonDef As ButtonDefinition
' Handler for the OnLinearMarkingMenu event to add the button to the context menu
Private Sub oUserInputEvents_OnLinearMarkingMenu(ByVal SelectedEntities As ObjectsEnumerator, _
    ByVal SelectionDevice As SelectionDeviceEnum, _
    ByVal LinearMenu As CommandControls, _
    ByVal AdditionalInfo As NameValueMap) Handles oUserInputEvents.OnLinearMarkingMenu
    ' Check if there are selected items and that the selection was made in the browser
    If SelectedEntities.Count = 0 Or SelectionDevice <> SelectionDeviceEnum.kBrowserSelection Then Exit Sub
    ' Get the first selected object
    Dim oSelected As Object = SelectedEntities.Item(1)
    ' Check if the selected object is a subassembly
    If TypeOf oSelected Is ComponentOccurrence Then
        oSubAsm = oSelected
        If oSubAsm.Definition.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            ' Add the button to the context menu
            LinearMenu.AddButton(oButtonDef)
        End If
    End If
End Sub
' Handler for executing the command to create a new model state
Private Sub CreateNewModelStateHandler(ByVal Context As NameValueMap)
    Try
        ' Check if a subassembly is selected
        If oSubAsm Is Nothing Then
            MsgBox("Subassembly not selected", vbExclamation, "Error")
            Exit Sub
        End If
        ' Get the subassembly document
        Dim oSubAsmDoc As Document = oSubAsm.Definition.Document
        ' Check if the document is a model state member
        If oSubAsm.Definition.IsModelStateMember Then
            ' If it is a state member, obtain the factory document via the active model state
            Dim oActiveModelState As ModelState = oSubAsm.Definition.ModelStates.ActiveModelState
            oSubAsmDoc = oActiveModelState.FactoryDocument
        End If
        ' Get ModelStates from the factory document
        oModelStates = oSubAsmDoc.ComponentDefinition.ModelStates
        ' Create a new model state
        Dim newStateName As String
        newStateName = InputBox("Enter new model state name:", "Create Model State", "ModelState" & (oModelStates.Count + 1))
        If newStateName = "" Then Exit Sub
        Dim oNewModelState As ModelState = oModelStates.Add(newStateName)
        ' Activate the new state in the subassembly
        'oSubAsm.ActiveModelState = newStateName
        ' Update the main document
        oDoc.Update
        MsgBox("New model state created: " & newStateName, vbInformation, "Success")
        MsgBox("Error creating model state: " & ex.Message, vbCritical, "Error")
    End Try
End Sub
INV 2025.3
ben.goodelliott
Hi Ivan, thanks for the reply.
I think I've managed to isolate the issue to another rule attempting to set the model state back to Primary.
Thanks for your time.
