creating ipart table showing multi body in BOM in Assembly mode.
Message 1 of 1
Hi all,
i have two part  (top half and bottom half) those two parts are with out ipart table.Now, i want to creat ipart table so, i have created ipart table for Top half and Bottom half. After creating ipart table i will do the pre-machining for both parts using assembly mode (.iam).so,i will create two pre-machining Top half and Bottom Half. half faced problem in this stage.
1.when placed Bottom half and checked the BOM. it is showing single body this is okay for me.
2. when placed Top half and checked the BOM . it is showing "Multi body"  image in BOM table. for that reason, i unable to do any machining process in Top half.
Note: without create i part table i called top half in assembly and i checked BOM that time it was showing sing Body and i am facing this issue only in top half only.
please advised how i can solve the issue.
thank you,
regards,
ram.
Replies (0)
