Creating branched Extrusion Surface
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Scenario 1: Two lines simply connected, end-to-end, via a common SketchPoint.
Dim oLineOne As SketchLine = oSketch.SketchLines.AddByTwoPoints( oTransGeom.CreatePoint2d(0, 0.75), oTransGeom.CreatePoint2d(5, 0.75))
Dim oLineTwo As SketchLine oLineTwo = oSketch.SketchLines.AddByTwoPoints(oLineOne.EndSketchPoint, oTransGeom.CreatePoint2d(5, 5.75))
Dim oProfile As Profile = oSketch.Profiles.AddForSurface(oLineOne)
=> Works fine. ExtrusionSrf created by profile by AddForSurface(oLineOne), gives "L" shaped surface.
Scenario 2: Added a third line, making a "T" like shape as below.
Dim oLineTwo As SketchLine oLineTwo = oSketch.SketchLines.AddByTwoPoints(oLineOne.EndSketchPoint, oTransGeom.CreatePoint2d(10, 0.75))
Only surface corresponding to oLineOne is created. Does not even for both oLineOne & oLineTwo as done
in Scenario 1. Stops at a branch point. Why? What is the resolution?
By some logic if it does so, now the issue is, Lines like oLineTwo and oLineThree are left out. How to identify
such lines which are not part of any profiles so far?
Is there any identifier/attribute that differentiates SketchLies which are consumed in a profile so far, and the ones which are not consumed?
Or exhaustive search is needed?
Basically given a sketch having multiple-connected lines, it would be nice to have all the connected paths possible
as a list then one can iterate over that list, create profile for each of the paths.
