Creating a iProperty Loop Function
amarinXG8V6
amarinXG8V6
Hi everyone,
I'm trying to figure out how to write an external rule that will look at the top level assembly from which the rule is launched and gather the value that is entered in the Project: Project iproperty field. I want that value fed down to the sub-assembly/ part level Project: Project iproperty field. I assume it will be some sort of loop style function since I won't know exactly how many parts/sub-assemblies will be present in the top level assembly.
A.Acheson
For the iproperties I would use All Referenced Documents (1) This targets only the single file even if used in multiple sub assemblies so is the shortest route to target each documents. Then next is to loop through the  documents and then actually retrieve the iproperties (2)I have left a document filter in there in case you want to filter for part/assembly documents using "kPartDocumentObject" / "kAssemblyDocumentObject".
Dim oAssyDoc As AssemblyDocument
 oAssyDoc = ThisApplication.ActiveDocument
 ' Get the Design Tracking property set.
Dim AssyDesignPropSet As PropertySet
AssyDesignPropSet = oAssyDoc.PropertySets.Item("Design Tracking Properties")
' Get the Description property.
Dim AssyProj As Inventor.Property
AssyProj = AssyDesignPropSet.Item("Project")
'Get all of the referenced documents.
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAssyDoc.AllReferencedDocuments
'Iterate through the list of documents.
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
	' If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
'		Logger.Info("DisplayName: "& oRefDoc.DisplayName)'FileName
'		Logger.Info("FullFileName: "& oRefDoc.FullFileName)'FilePath
         Dim DesignTrackPropSet As PropertySet
         DesignTrackPropSet = oRefDoc.PropertySets.Item("Design Tracking Properties")
                Dim RefProj As Inventor.Property
         RefProj = DesignTrackPropSet.Item("Project")
   		Try
			RefProj.Value = AssyProj.Value
		Catch
			Logger.Info("Read Only - "& oRefDoc.DisplayName )
		End Try
    'End If
Next
Also you can use a function with Vb.Net to reduce extra lines required and to also work with other iproperties easily.
Sub Main
Dim oAssyProj As [Property]
oAssyProj= GetiProp(oAssyDoc,"Project")
Logger.Info(oAssyProj.Value)
		'Logger.Info("DisplayName: "& oRefDoc.DisplayName)'FileName
		'Logger.Info("FullDocumentName: "& oRefDoc.FullDocumentName)'FilePath
		Dim oRefProjNo As [Property]
		oRefProjNo = GetiProp(oRefDoc,"Project")
		Try
		oRefProjNo.Value = oAssyProj.Value
		Catch
		End Try
      'End If
Next
End Sub
Function GetiProp(oDoc As Document,iPropName As String)As [Property]
     DesignTrackPropSet = oDoc.PropertySets.Item("Design Tracking Properties")
     Dim oProjProp As Inventor.Property
     oProjProp = DesignTrackPropSet.Item(iPropName)
	 Return oProjProp
End Function
Regards
Alan
amarinXG8V6
Hi @A.Acheson,
I tried the first portion of code the you provided and it worked great! Thank you for the support. Have a good day.
c.bloedorn
Is it also possible to change the iproperty of the fist level children only. So if there is a subassembly within the main assembly to not alter the iproperties of parts within it?
