Create Workplane (Normal to Axis Through Point)
Genicee
Genicee
You can create a Workplane Normal to and Axis through a point using the UI, but I can't not see where that is available in the API. I have tried WorkPlanes.AddByNormalToCurve, but an Axis does not qulify as CurveEntity.
dano0310
Hi Genicee
Try this code as a starting point.  Currently it is using the x axis and the centre point to creat a workplane.
Dim oPartCompDef As PartComponentDefinition
Set oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oAxis As WorkAxis
Set oAxis = oPartCompDef.WorkAxes(1)
Dim oPoint As WorkPoint
Set oPoint = oPartCompDef.WorkPoints(1)
Dim oPlane As WorkPlane
Set oPlane = oPartCompDef.WorkPlanes.AddByNormalToCurve(oAxis, oPoint, False)
Hope this helps.
Dan
Genicee
That was basically what I was trying. What found out to be the problem is AddByNormalToCurve does not accept "Point" as a parameter. "WorkPoint" does work.
Thanks for the help!
