I'm creating a sketch on a face but when the sketch is created and in edit mode the sketch doesn't rotate forward. I'm hoping there is something simple but I can't seem to find it. Any help would be greatly appreciated!
Dim oDoc As PartDocument: Set oDoc = ThisApplication.ActiveDocument Dim oPartDef As PartComponentDefinition: Set oPartDef = oDoc.ComponentDefinition Dim oFace As Face: Set oFace = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartFaceFilter, "Select the face") Dim oSketch As PlanarSketch: Set oSketch = oPartDef.Sketches.Add(oFace, True) oSketch.Edit
This is what it looks like when the above code is finished.
This is what I want it to do. This will make it where the user doesn't have to rotate it front to start drawing.
Thank you!
Tiffany
Tiffany Hayden
