Create Sketch on Face but Sketch doesn't rotate to front
Tiffany_Hayden_
Tiffany_Hayden_
I'm creating a sketch on a face but when the sketch is created and in edit mode the sketch doesn't rotate forward. I'm hoping there is something simple but I can't seem to find it. Any help would be greatly appreciated!
    Dim oDoc As PartDocument: Set oDoc = ThisApplication.ActiveDocument
    Dim oPartDef As PartComponentDefinition: Set oPartDef = oDoc.ComponentDefinition
    Dim oFace As Face: Set oFace = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartFaceFilter, "Select the face")
    Dim oSketch As PlanarSketch: Set oSketch = oPartDef.Sketches.Add(oFace, True)
    oSketch.Edit
This is what it looks like when the above code is finished.
This is what I want it to do. This will make it where the user doesn't have to rotate it front to start drawing.
Thank you!
Tiffany
Tiffany Hayden
HideoYamada
Change the code like this :
    'oSketch.Edit
    oDoc.SelectSet.Select oSketch
    ThisApplication.CommandManager.ControlDefinitions("AppSketch2DWrapperCmd").Execute
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Tiffany_Hayden_
That worked! Thank you @HideoYamada  for your help!
Tiffany
Tiffany Hayden
