Create Project Geometry, Offset and Extrude using ilogic
murugasubi
1,543 次查看
2 条回复
1 条消息(共 3 条)
murugasubi
Hi Dear,
I have a part, I want to create project geometry on edges and offset the edges to 1 inch and extrude the sketch. Please refer to the attached image A and B. I want to create image B.
I used the below codes, but could not complete the code. Please help.
Sub Main
Dim
oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oCompDef As PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition Dim oSketches As PlanarSketches = ThisApplication.ActiveEditDocument.ComponentDefinition.Sketches Dim oSketch1 As PlanarSketch oSketch1 = oSketches("Sketch1") 'I have used the existing sketch to extrude
Dim oProfile As Profile oProfile = oSketch1.Profiles.AddForSolid ' Create a base extrusion 1 inch thick. Dim oExtrudeDef As ExtrudeDefinition oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation) Call oExtrudeDef.SetDistanceExtent(1, kNegativeExtentDirection) Dim oExtrude As ExtrudeFeature oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef) Dim oFrontFace As Face oFrontFace = oExtrude.StartFaces.Item(1)
'Code not working from here Dim oSketch2 As PlanarSketch oSketch2 = oCompDef.Sketches.Add(oFrontFace) Dim featEdge As Edge For Each featEdge In oFrontFace.Edges Call oSketch2.AddByProjectingEntity(featEdge) Next
end sub
0 个赞
已接受的解答 (1)
1,544 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
Michael.Navara
已接受的解答
Your code works as expected.
I just recommend you to modify this line of code to the following form. Avoid to use active document multiple times, because it may be changed.
Dim oSketches As PlanarSketches = oCompDef.Sketches
and then you can use this for rest of your task. Here is used simpler version for projecting all face edges.
If False Then
    Next
Else
    'Simpler version
    oSketch2 = oCompDef.Sketches.Add(oFrontFace, True)
End If
Dim entitiesForOffset As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
entitiesForOffset.Add(oSketch2.SketchLines(1))
Dim offsetDistance As Double = 1
Dim offsetDirection As Boolean = True
Dim offsetedEntities = oSketch2.OffsetSketchEntitiesUsingDistance(entitiesForOffset, offsetDistance, offsetDirection, True, True)
Dim profile2 = oSketch2.Profiles.AddForSolid(True)
Dim oExtrudeDef2 = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(profile2, PartFeatureOperationEnum.kJoinOperation)
Dim oExtrude2 = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef2)
3 条消息(共 3 条)
murugasubi
Thanks a lot Michael. Navara
Code working well.. I really appreciate your help and respect your opinion..
0 个赞
