Create Negative extrusion/Cut on assembly
rbertoletti
Message 1 of 1
rbertoletti
Hi everyone!
I'm actually facing one problem and i'm currently not able to solve it.
The purpose is to create a Negative extrusion or a cut on and assembly made by some metal sheets.
The cut should also follow the geometry obtained by other assemblies which can change as per some user parameters.
Thanks in advance for the support.
Replies (0)
