Create multiple different drawings that do not change when the model does.
Thomas_Savage
Advisor Advisor
Thomas_Savage
I have created a conveyor using iLogic to change the length.
Now i want to place each of the 4 different lengths on drawings. But when i place the drawings i want to be able to select the different lengths. So i have 4 different drawings that are dimension from the one iLogic model. And these drawings don't update when the model changes.
 As if i place the iLogic model in a drawing, i dimension it, then change the model length it changes on the drawing also. I don't want it to change on the drawing.
What is the best way to achieve this?
Save As and break the link?
Level of Detail?
Any help much appreciated.
Thomas Savage
Design Engineer
Thomas_Savage
I have solved this problem by changing the length in iLogic, creating a new assembly, then placing the model as an iLogic part. This new assembly does not change length when the original model does.
This means i can now create the individual drawings that don't change when the original model does.
Thomas Savage
Design Engineer
Thomas_Savage
If anyone has any other, or better solutions would love to hear them also.
Thomas Savage
Design Engineer
lmc.engineering
Would using 'Defer updates' on the drawing document work for you?
Thomas_Savage
I don't think so. Because if i dimension a small one, then change the size to a bigger one, then their will be no holes on the drawing as on the smaller they are suppressed, and the bigger unsuppressed.
Thomas Savage
Design Engineer
FINET_Laurent
Creating derived part might be the way to go.. ?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
