Create Inventor App using only free tools (for internal use)
amarcoc
amarcoc
Hi.
I created some iLogic and VBA macros already, but now I want to make a installable tool with all-in-one.
I am thinking on porting everything I created to an installable app, for install only on Company computers. I dont want to publish tools to Autodesk App Store.
I have the necessary programming skills.
What I want to know is what free tools are avaiable to use. What will I need?
Thanks in advance.
AlexFielder
You'll need to check the licensing terms, but Visual Studio Community is "free" in certain circumstances.
Failing that, it's technically possible to build an add-in using Visual Studio Code which is actually free - although I don't know the steps exactly because I've never tried it.
HermJan.Otterman
With that Visual Studio, install VB, and than you can create an addin for inventor:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-52422162-1784-4E8F-B495-CDB7BE9987AB
that addin (.dll) can be copied to every inventor workstation in you company
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
amarcoc
I thought Visual Studio was paid. I have just confirmed Community is free.
And I also fount this topic:
https://forums.autodesk.com/t5/inventor-customization/check-out-the-self-paced-guide-my-first-plug-i...
So, I believe its solved. Thanks!
AlexFielder
That article is a great starting point for your first add-in- I used it myself back in the day.
However, this post by @ekinsb runs through the steps necessary to use the SDK Add-in "Wizard" available with Inventor 2019:
https://ekinssolutions.com/addins-visualstudio2017/
I currently have Inventor 2019 and Visual Studio 2017 installed on Windows 7 but am not using the wizard.
Suffice it to say that the wizard needs an update.
