Create Flat Pattern On Save
SometimesInventorMakesMeAngry
So I made an add-in that creates a flat pattern when a part is saved (if it needs one). It works as expected when a single part is open. However, it does not work well when an assembly with sheet metal part children is saved. When the code is executed, Inventor opens one of the children, unfolds it, and exits flat pattern, which is great. However, I get exceptions for each of the remaining children.
public void CreateFlatPattern()
    if (CompDefinition.SurfaceBodies.Count != 1) return;
    //Above handles multi-body or no body
    //Sheet metal part can't be unfolded if multi-body
    if (!SheetDefinition.HasFlatPattern)
        try
            SheetDefinition.Unfold();
            SheetDefinition.FlatPattern.ExitEdit();
        catch
        { throw new System.Exception("Unable to unfold model"); }
 Does anyone understand this behavior?
I found this. So I added some lines to the method to open the part before attempting to unfold as follows:
		Application inventor = App.GetApplication();
		bool docWasOpen =
			inventor.ActiveDocument ==
			(_Document)this.DocumentObject;
		if (!docWasOpen)
			inventor.Documents.Open(
				this.DocumentObject.FullFileName, OpenVisible: true);
		try
		catch
		if(!docWasOpen)this.DocumentObject.Close();
But I get this warning for each part:
If I click "Yes", I get the following errors:
I assume this is related to some infinite loop situation because my code executes on save. If I click "No", it works fine with no errors, but that means I have to remember to click the correct button each time and I have to actually click something every time a flat pattern is created. I'd rather have no user interaction. Does anyone have any suggestion on how to fix this?
maybe a bit counter-intuitive but at the end of the rule, you could save the document in silent mode. That way you can suppress any dialogues while saving.
ThisApplication.SilentOperation = True
doc.Save()
ThisApplication.SilentOperation = False
Jelte de Jong
Blog: hjalte.nl - github.com
I will give that a shot after the holidays. I'm hoping that by saving
inside the method, I don't run into another infinite loop situation because
this method executes on save.
